the truth comes out
Old Sep 25, 2003 | 10:57 AM
mtcookson's Avatar
the truth comes out
I'm not sure if this has ever been posted before but it has been asked many times and I finally found out how to do it (after thinking it was done a different way for a while). For those of you that want to know how to adjust your idle on the VG what you do is turn the screw on the ecu clockwise all of the way (while the engine is running). Next, you need to get out of the car and go to your Idle Air Control Valve (also called the Auxiliary Air Control Valve) and turn the screw that is under the black cap until you get your desired idle. FSM says to adjust it to 700 rpm +/- 50 rpm.
Old Sep 25, 2003 | 11:03 AM
Jeff92se's Avatar
I'm needing a caw
The truth was already out there.
http://www.cybrrpartspro.com/Chilton...61CH01_34.HTML
Old Sep 25, 2003 | 11:24 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
if you search it , it will come.
Old Sep 25, 2003 | 01:33 PM
mtcookson's Avatar
well now if you seach it will come (on this forum that is)
Old Sep 25, 2003 | 02:01 PM
Jeff92se's Avatar
I'm needing a caw
No. If you looked at the STICKIE I posted months ago, the info is in there.
Old Sep 25, 2003 | 03:37 PM
mtcookson's Avatar
i know that but if you search for how to adjust idle that link wouldn't come up.
Old Sep 25, 2003 | 03:46 PM
Jeff92se's Avatar
I'm needing a caw
But if you had read the stickie like I told everone to do, you wouldn't have to search.
Old Sep 25, 2003 | 03:56 PM
Matt93SE's Avatar
STFU n00b!
I know that, but common sense would say idle adjustment is "General Maintenance," correct?
Now look at the 3rd post down inside the General Maintenance Reference Links sticky.
http://forums.maxima.org/showthread.php?t=128490
Old Sep 25, 2003 | 04:10 PM
mtcookson's Avatar
but you should know not everyone looks at the stickies.
i'm not sure a newbie to cars would even know what general maintenance means, if you know what i mean.
but oh well... i'm sorry for trying to help people on this board.
Old Sep 25, 2003 | 04:12 PM
Jeff92se's Avatar
I'm needing a caw
Not everyone searches either so where does that leave us?
Old Sep 25, 2003 | 04:13 PM
mtcookson's Avatar
that leaves us with many many many many (you get the idea) repeats
Old Sep 25, 2003 | 04:14 PM
Jeff92se's Avatar
I'm needing a caw
and moderator deletes/locks/flames until they learn
Old Sep 25, 2003 | 04:15 PM
mtcookson's Avatar
the life cycle of maxima.org
Old Sep 25, 2003 | 07:47 PM
Matt93SE's Avatar
STFU n00b!
it's not worth reading unless it's been locked.
Mar 12, 2020 12:06 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
soloist3
Sep 2, 2015 12:59 PM
johnsmax
Jun 11, 2001 09:27 PM
Cattman
18
Apr 5, 2001 08:45 AM
