Antenna
Old Sep 29, 2003 | 07:10 AM
jmleedy's Avatar
Antenna
ok i have a 93 and the antenna broke in half. can i disable the power to it and just put another antenna on or do i need to get another powered one and fix it like that? let me know please
Old Sep 29, 2003 | 07:16 AM
jobasjr's Avatar
My 92' Maxima had a broken antenna when I got it and I jsut went to my local junk yard and got one off another maxima, it not hard to switch, I got it for 8 bucks so not too expensive, I've also seen replacement power antennas for 30 bucks at stores so you might try you a autoparts or a place like Fry's where i saw them...
Old Sep 29, 2003 | 07:18 AM
Matt93SE's Avatar
STFU n00b!
you can go either way. nissan sells replacement antenna masts for not too much $$.
If you don't want to do that, then you can replace it with aftermarket powered or non/powered antenna.
if you'll reach inside the hole for the jack inside the trunk (pull out the jack first), you can find the power plugs (there's two of them for some reason. not sure which does what), then just unplug them.
you'll also have your antenna plug to worry about too when you replace, but not hard at all.
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
