Anyone who's replaced PCV on VE...
Old Oct 3, 2003 | 04:51 PM
James92SE's Avatar
2 VE's are better than one!
Where'd you get it?
I went to Pepboys in hopes of getting a new one but it wasnt listed. It had a blank where the part # for the VE engine would have been.
Old Oct 3, 2003 | 04:53 PM
Jeff92se's Avatar
I'm needing a caw
I think I got mine from Napa. Simple little device. But kind of a pain to replace. Way back on the firewall side on the head.
Even from Courtesy, it's just a few $
Old Oct 3, 2003 | 04:58 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I've replaced mine. Be prepared to replace your blow by hose since you might have to cut it off or shatter it. Give courtesy a call. I think I got mine from my local dealer. Not expensive at all and my old one didn't giggle as freely.
Old Oct 3, 2003 | 05:16 PM
Gjohnson's Avatar
I got mine from pepboys, but I just kinda had to eyeball it. I got the one that looked the most like the OEM. Didn't really have a choice since I had picked one up at first and they gave me one for the VG that looked way off and the original PCV valve was floating in a pool of oil from my oil change.
Old Oct 3, 2003 | 06:56 PM
D-sta's Avatar
James www.foreignautoparts.cc has it for like $3.00 I think. Not too bad to change just time consuming and a pain in the a$$ location.
Old Oct 4, 2003 | 09:19 PM
pezking4's Avatar
I got mine from Courtesy. Be prepared to be frustrated with getting the hose off and on the valve...
Old Oct 4, 2003 | 10:05 PM
crazy4maxima's Avatar
fighting with the damn clamp and loosing the clamp was a pain.. it took me and deigo like 15 minutes on the ve.. when on the vg it was litterly 30 sec..
Old Oct 5, 2003 | 01:26 PM
EWillden's Avatar
Does anyone have a pic of where the pcv valve is located? Many pople have given descriptions but a pic of where it's at would be great!
Old Oct 5, 2003 | 08:05 PM
well this is aaron92se's ve engine... i put a dot where it is supposed to be... vg are easier.. just on the other side and on the top right..
Old Oct 5, 2003 | 08:10 PM
«§»Craig B«§»'s Avatar
there is a better pic on chiltons online (link in the FAQ) and I know a couple of other pics have been posted here before too so you should be able to find them in the archives (search)
Old Oct 6, 2003 | 06:02 PM
Aaron92SE's Avatar
NWP Engineering.com
I was about to say that motor looked pretty sweet. Then I realized it's mine.
http://www.cybrrpartspro.com/Chilton...61CH01_22.HTML
Old Nov 1, 2003 | 12:32 PM
LegitMafiaBoss's Avatar
I was gonna replace my pcv today and I think I found it but I believe that I will need a 19mm deep socket because the socket that I have is too short. And there is no room for a 19mm C wrench. Is this the pcv or something else?
Old Nov 1, 2003 | 02:13 PM
MrGone's Avatar
just used a 3/4" deep socket + extensions.
to get the hose off I just used some vice grips to squeeze the clamp, then with the angle of the hose just pulled up and off it came.
Old Nov 1, 2003 | 02:36 PM
D-sta's Avatar
Instead of just the regular 3/4 socket you might consider using a 3/4 spark plug socket since it has the rubber inside of it which will hold the PCV valve as you pull it out of its location and not drop on the floor.
Old Nov 1, 2003 | 06:36 PM
lol.. and small hands wouldnt hurt either... be sure to park the max on even ground that way if the pcv falls during install you can find it easier when it hits the ground. damn japanese with their compact motor design, still cant figure out why they hide what should be an easy replacement job on certain maintance parts..
Old Nov 1, 2003 | 07:20 PM
BTW what are the symptoms of a bad pcv valve? Rough idle?
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
