what year tranny will fit my max
Old Oct 7, 2003 | 05:22 PM
jhuitt's Avatar
I have a 91 max with 5-speed manual, I pulled tranny thinking TO bearing was all I needed to replace, but when the TO bearing went, it broke off part of the tranny housing around the input shaft. I was wondering what all models tranny will fit my 91
Old Oct 7, 2003 | 05:52 PM
MrGone's Avatar
any 3rd gen tranny will fit, however the 92-94SE's are abit different. You will have to buy new axles and spindles and everything inbetween because they use larger axles.
For a direct replacement, 1989-1991 Maxima SE trannys.
Do you have the ability to take a picture of the broken tranny? I'm curious to see if its the same area where mine was broken.
Old Oct 7, 2003 | 06:11 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
cant he also use92-94 GXE tranny ? or am i mistaken ?
Old Oct 7, 2003 | 06:33 PM
MrGone's Avatar
GXE = Auto, but it will bolt up.
Old Oct 7, 2003 | 06:40 PM
David89Max's Avatar
wait did you break the bell housing??
and if so cant you just replace that not the whole tranny.
Old Oct 7, 2003 | 08:00 PM
subs1000w's Avatar
i believe the 5spds from 85 to 88 also fit at least we useds a 5spd out of an 87 in my friends 91 for the conversion the only difference from my 92 is it didnt have a fill plug on the side and the braket that holds the shift stabilizer rod is different plus they are plentiful and cheap so its another option
Old Oct 7, 2003 | 09:12 PM
jhuitt's Avatar
Thanks, I will post a pic of where it broke tomorrow, there is a lip around the input shaft, about half of the lip broke off, I am pretty sure it is not fixable.
PS subs what did you guys do for the shifter support bracket.
Old Oct 8, 2003 | 07:22 AM
subs1000w's Avatar
we just used the one off my 92 since the motors gone and i ordered a new braket for 30$ but since yours is already a 5spd just use the one off the old trany its held on by 2 bolts
Old Oct 8, 2003 | 07:33 AM
Matt93SE's Avatar
STFU n00b!
it's fixable, as long as it doesn't get into the tranny seal or anything.
a good machine/welding shop sould be able to weld it back together and grind it down so it'll work. probably cost at most $100. much better than another tranny.
Old Oct 8, 2003 | 07:48 AM
YoU CaNt SeE mE
i diddnt know you couldnt get a gxe with a stick..oops
Old Oct 8, 2003 | 10:44 AM
LittlePiggie's Avatar
no GXE with a stick, but you can get and SE with an auto...the GXE is the granny version
Old Oct 8, 2003 | 12:57 PM
latinmax90's Avatar
ok so im kinda confused here, u can use a 2nd gen 5spd tranny on say my car thats a 90 gxe?? and u cant use a 92-94 se 5spd tranny?? i dont know i just got confussed sorry for the confussion.
Old Oct 8, 2003 | 04:16 PM
MrGone's Avatar
I am not sure about the 2nd gen tranny and if its any different.
The 92-94SE transmission WILL bolt up to the engine, however it uses larger axles, so you will have to replace the axles, along with the spindles.
Old Oct 8, 2003 | 07:44 PM
subs1000w's Avatar
if you go to a junk yard and find a second gen 5spd look at the engine plate thats front center of firewall and it has the trany and engine code if the trany code is RS5F50A it is the same as the 89 to 91 se 5spd so then yes it will work and like i said my friend has one from an 87 in his 91 gxe right now
Old Oct 9, 2003 | 02:27 PM
latinmax90's Avatar
ok thanx alot that really does help out cuz im considering on doing the 5spd tranny swap on my gxe but i got to get some of that doe b4 i do anything else
Old Oct 10, 2003 | 12:31 PM
jhuitt's Avatar
I found a 5 spd out of an 89 for $300, it comes with a 30 day warrenty, but I was wondering what can I do to tell if it is good before I buy it.
Old Oct 11, 2003 | 11:50 AM
subs1000w's Avatar
just stick a screwdriver in the shifter shft and go threw all the gears in each gear spin the input shaft and if the differentail spins smooth and at the proper speed in diferent gears it should be fine although im not sure if you can detect bearing or syncro problems like that but atleast you know its not completely bad
Old Oct 11, 2003 | 11:58 AM
mtcookson's Avatar
is this what broke?
that's what happened to my first tranny.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
seesole
Aug 26, 2015 11:22 AM
Supragte
Aug 12, 2015 10:00 PM
