Vg30
Old Oct 8, 2003 | 12:43 PM
SupaMax's Avatar
Vg30
Hey guys I have jus a quick question. I have a 90 max and my engine is just about hit the fan. My friend has a 2nd gen Max that he can see me for like 400. Will I be able to swap engines i.e. the head of the engine. Also what else can I swap out of it that will fit w/o a problem?????
Old Oct 8, 2003 | 12:44 PM
Jeff92se's Avatar
I'm needing a caw
You can get a VG30 for your year car for $400 or less also. I'd do that.
Old Oct 8, 2003 | 01:36 PM
RA030726's Avatar
I'm nutty for Nissans
Hmmm both VG30 but the 2nd gen engine is a little less powerful. Here are some specs:
1988 Maxima GXE
Engine:
V-6 Liquid cooled cast iron block,
Aluminum Heads
Displacement: 2960cc
Bore and stroke 87.0 x 83.0 mm
Compression: 9.0:1
Induction system: Electronic Port Injection
Valvetrain: SOHC, 2 valves per cylinder
Max engine speed: 6000 rpm
Max Power: 152hp@5200 rpm
Max Torque: 157 lb-ft@3600 rpm
Emissions control: Crankcase Ventilation,
Air injection, Catalyst
Fuel: Unleaded
Drivetrain:
Transmission 4-spd, Auto, O/D
Transmission ratios
1st- 2.79:1
2nd- 1.55:1
3rd- 1.00:1
4th- 0.60:1
Final Drive ratio- 3.43:1
Capacities:
Crankcase: 4.3qt
Cooling System: 1.4 gal
Fuel Tank: 17.2 gal
Luggage: 14.5 Cu ft
Old Oct 8, 2003 | 01:43 PM
RA030726's Avatar
You know the heads look the same on the outside.
Old Oct 8, 2003 | 07:54 PM
subs1000w's Avatar
i would jump on this its even in your own state and has a warenty
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Old Oct 8, 2003 | 10:41 PM
MaxPerformanceSE's Avatar
Wow that's a clean engine bay.
aw11power
Oct 10, 2021 04:57 AM
matt90max
Oct 21, 2004 06:53 AM
jadegreenmax
May 21, 2004 05:23 AM
mtcookson
Oct 12, 2002 06:47 PM
xsohaib
Sep 2, 2002 02:21 AM
