Strong gas smell 1st thing in AM
Old Oct 24, 2003 | 09:58 AM
billy bronco's Avatar
I have what I assume is a leaking rubber hose, I see the gas peeing out on the drivers side . A 3" hose after the fuel filter under all this stuff hooked to the fuel rail.
Question is: Can I change this with out taking the top of the engine all apart? Doesn't look like it to me, I can't even see the rear clamp. What is the process for this change?
Old Oct 24, 2003 | 10:23 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
should be able to the hose after the fuel filter comes off pretty easy..
Old Oct 24, 2003 | 10:33 AM
So are you saying I undo the front clamp and maybe a hanger screw for the metal part after the fuel filter and slide it out under all that stuff?
Old Oct 24, 2003 | 10:39 AM
Jeff92se's Avatar
I'm needing a caw
Anything after the filter that goes to the fuel rail should be fairly easy to replace. But make sure you get fuel injection fuel hose and not vacuum hose! The oem Nissan hose is metric but there's a sae size that works just as well. You might want to take a short piece or note the mm size on the hose and convert it to the closest size. Also consider buying more than you need and replace some of the other lengths as they are probably hard/cracked too.
Old Oct 24, 2003 | 11:39 AM
Well, wanting to make sure I got the right stuff I bought the item from the dealer, holy #$%^ it cost $23.00 fro a 3" piece of hose!
Old Oct 24, 2003 | 11:46 AM
internetautomar's Avatar
mod or sell?
Did you at least get lubed first?
SHEEIT. I get that for a 10 ft spool
Old Oct 24, 2003 | 11:51 AM
Jeff92se's Avatar
I'm needing a caw
Old Oct 24, 2003 | 12:09 PM
At least make me feel better and help me fix it, damn. Least I didn't buy the other side. If it aint broke don't fix it!
Old Oct 24, 2003 | 12:41 PM
MrGone's Avatar
Sooo true! If it aint broke, upgrade it!
Old Oct 24, 2003 | 12:47 PM
Jeff92se's Avatar
I'm needing a caw
Help you fix it? Other than me going to your house, what more do you need to know. Take out old hose, install new overpriced hose. Not difficult
Old Oct 27, 2003 | 04:49 AM
Gonna return the expensive hose, bought a foot at AZ for $5, but don't say its easy, it was a pain in my butt! Fixed though.........
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
wingnut2006
Sep 19, 2015 06:13 AM
slowlifer
Sep 8, 2015 05:53 AM
