Is this a serious problem?
Old Feb 19, 2001 | 07:29 PM
quikky's Avatar
Recently, when I turned on the ignition the "check engine" symbol lit up in my display and the car started vibrating a little bit (felt like i was driving over rough asphalt). The vibration wasn't hard but just kind of harder than usual. I turned off the car without even trying to drive and turned it back on, it worked perfectly fine afterwards. This rarely happens (like 1-2 times a week) considering I drive multiple times each day. The car seems to work fine, accelerate/shift gears etc but I am just kind of worried as to what this might be a sign of. Any help would be appreciated. I got a 94 Automatic GXE btw, with 108k miles. Thanks.
Old Feb 19, 2001 | 08:00 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Rough idle....
when was your last tune up??
Old Feb 20, 2001 | 10:57 AM
quikky's Avatar
Hmm
Well I bought the car not so long ago so I am not sure when the previous owner had one. What do you suggest it might be though? Or does it just need tuning?
Old Feb 20, 2001 | 04:00 PM
DA-MAX's Avatar
Personally.........
I'd look into a full tune-up!!!! I've had my car since 105K and at 130K i just rcently got a full tune-up, and what do you know evey single part on there is OEM out the factory, in other words the owner never changed a thing on the car which is VERY bad!!! personally I would get a FULL tuneup, just to make sure or maybe have the car looked over by a pro, but sounds to me like idle speed might be off(which is nothing major!) so get it checked out and see what you find out, thats my best advice!
Old Feb 20, 2001 | 07:13 PM
Tick Tock's Avatar
Can you spell...
Bad fuel I N J E C T O R... Everytime I've had this happen it's been a bad fuel injector. Try running some Techron injector cleaner through a couple tanks and start saving. The injectors are a known problem and are about $125+ each for the injector and about $300 or so for installation. If one goes - I'd replace all of them if you can afford it.
I did one - then another - then all the rest.
Old Feb 21, 2001 | 07:30 AM
Sarah99GXE's Avatar
Maxima Princess
unfortunately I'm gonna have to agree with Tick Tock....I've been having this problem for over a month now. It only happens to me about once a week & the light will come on for a few seconds...my mechanic had read error code 51 but when running tests the light kept going off & the car would run perfectly which prevented him from testing. So he doesn't want to see me until it's happening all the time. I've been running chevron w/techron gas. Also this only started happening after I got a fuel injection flush. First time in 3 years I've had one so I think I disrupted the system
Unclejunebug
Apr 2, 2016 05:42 AM
02PearlSE
Feb 1, 2016 12:37 AM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
