Cheezer, installing new suspention
Old Oct 28, 2003 | 04:50 PM
ChrisCheezer's Avatar
Hey ppl, tomorrow at 6o clock i should have my new suspention parts, tokico struts and sprint springs (i can't wait!!!) my stock springs and struts are deader then dead
:questions for u crazy DIY'ers
-will i be able to install them my self?, my service maunal make it look like a piece of cake..
-this is a used set (1 1/2 years old) so will i have to get an my wheels aligned?
-what are bump stops??! and how hard are they to replace?
..IM HAPPY
Old Oct 28, 2003 | 05:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
-pretty easy job..rear is kinda tedious
-yes, get an alighnment whenever messing with suspension
-bump stops are the little spongy thingies on the shock shaft that prevent bottoming out...they simply slide off/on
Old Oct 28, 2003 | 06:12 PM
thanx damax- a few more little things, will need a torque wrench and or a breaker bar for the job?
its ok to drive around for a little while with out the alighnment.. right?
wil need to get a camber correction? in the future?
and i know i will need a spring compressor to service the bump stops
.. i can't wait! any last min. addvice?
Old Oct 28, 2003 | 06:36 PM
ghostmax's Avatar
1. rent compressors from AZ (not the state). make sure it is compressed all the way before you loosen the center bolt!!!
2. probably need a 12" breaker for the bolts in the rear suspension. not totally necessary but helps.
3. make sure you have liquid wrench or equivalent.
4. post-install, i drove around for a long time before my accident. alignment was "perfect" in that the car did not deviate on a straight road. i just installed the previous set on my new max and it needs an alignment now.
5. takes me no time at all now to do the install, but it might be long the first time. just take your time and be thorough. good luck!
oh, the car handles totally differently from a GXE with old struts. you'll love it.
EDIT one more thing, you might need a large wrench like plumbers use to open the rear strut cartridge, unless you have the Nissan specified tool.
Old Oct 28, 2003 | 07:16 PM
jim90gxe's Avatar
1. The rear suspension (that you will be getting) is complete so you will only need to unbolt the caliper, remove disc, remove radius rod,parallel link, sway bar and mount bolts.
2. You will need a compressor to compress the springs. You can rent one from autozone for $40 which you will get back when you return it.
3. 1/2" breaker bar and ratchet will help.
Old Oct 28, 2003 | 09:41 PM
Spipedong90's Avatar
MAKE SURE YOU USE THE BUMP STOPS!
I left mine off the front, and now the car bottoms out if I hit a big enough bump. Now I have to take the front suspension back off and replace the bump stops.
Old Oct 29, 2003 | 05:30 AM
N34JZ's Avatar
Needs non-Maxima Friends
Chirs I know a place in queens that D-sta told me about that can do the alignment and gives you the camber bolts for the eibachs
or you can get the bolts off of tirerack I think for $35 or something
Old Oct 29, 2003 | 05:42 AM
Conrad283's Avatar
I need a truck
hey chris, whats up
Old Oct 29, 2003 | 05:57 AM
94M@X's Avatar
getting mine installed tomorrow too!!!!!!!! Cant wait.
Old Oct 29, 2003 | 08:24 AM
Mizeree_X's Avatar
Getting back to his roots
I just finished installing mine.....let me give my $0.02:
- On the rears, mark the front bolt on the strut tower so that when you put it back together, you know how to align them (since they only fit in one configuration)
- I bought all new KYB dust boots. They are excellent, and they have built-in bumpstops.
- If your car has a bit of rust like mine, a 12" breaker bar may not be enough (I bought a 24" one)
- If you have an Addco RSB already installed, take it off the car before you jack it up. I forgot about that step.
Good luck.
Old Oct 29, 2003 | 08:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
do share...i can't find a decent alignment place.
Old Oct 29, 2003 | 09:46 AM
D-sta's Avatar
Here you go DanNY
M.I.C. Tire Pros
47-01 Northern Blvd.
Long Island City, NY 11101
718-626-5200
Monday Thru Saturday, they open at 8. I always go there at 7:30 so that I am first online on the alignment machine because if you go late good luck they have a lot of cars.
Ask for Hamza, he's the manager there, if you need reference just tell him Diego sent you there. The front camber bolts through him are $50.00 but you can find them online for cheaper and the 4 wheel alignment is $50.00 and if you pay cash he won't charge tax.
Old Oct 29, 2003 | 10:21 AM
DanNY's Avatar
Ad·min·is·tra·tor
my kind of guy
thanks
Old Oct 29, 2003 | 11:04 AM
Matt93SE's Avatar
STFU n00b!
$50 for a 4-wheel?! dayum! if only they were that cheap here...
I'm looking at probably $150 minimum to get mine aligned once I finish the suspension. then again, that involves corner weighting and a track-spec alignment, not the typical "set the toe and let it go" alignment most shops do.
Old Oct 29, 2003 | 11:26 AM
YAY.. i cant wait.. thanx guys!
HEy drew whats up! long time no see
i went to auto zone but they dont have a trq. wrench!? wtf.. and they spring commresors they had were two piece .. so i guess ill try that...
Old Oct 29, 2003 | 11:40 AM
Maximan190's Avatar
my car was properly aligned and i didnt need the camber bolts on my eibachs
Old Oct 29, 2003 | 12:08 PM
internetautomar's Avatar
mod or sell?
2 things:
1. you're definitely tight about the toe and go bs you find at most shops.
2. I sell those alignment bolts.
Old Oct 29, 2003 | 02:03 PM
DA-MAX's Avatar
they don't have torque wrenches for rent(don't think sale either)
Old Oct 29, 2003 | 02:54 PM
KLoWnPR109's Avatar
That's what you need. Just make sure you get the kit that attaches on the side and not through the middle. You'll know what I'm talking about if you get the wrong kit
Old Oct 29, 2003 | 03:33 PM
N34JZ's Avatar
ok but is the camber correct? or did they align it to the factory specs?
Old Oct 29, 2003 | 04:24 PM
OMG im sooo stupid,.. i got the suspention, but.. i read the post wrong... (go to the for sale fourm and tell me what u think
-i got the front sprint springs and tokico struts... but the rears are just the stock nissan struts with sprint springs on them!?!?
.. im soo stupid......
-i thought it was a full set of all tokico struts and sprint springs...(i knew it was to good to be true.. im soo dumb!
plz advice! plzzzzzzzz omg im stupid
Old Oct 29, 2003 | 05:18 PM
mod or sell?
Buy a pair of tokico rears!
I wonder who sells tokico
Old Oct 29, 2003 | 05:22 PM
N34JZ's Avatar
I sell tokicos PM me chris, Ill take care of you
Old Oct 29, 2003 | 05:30 PM
yay!...
but money is a problem for mee... so have to try and sell what i have, woudl u be interested? hehe
Old Oct 29, 2003 | 05:39 PM
KLoWnPR109's Avatar
You sure you don't have the rear toks? They are just inserts so you wont be able to tell for sure unless you open them up and look at the cartridge inside.
Who did you buy these from? Just wondering
Old Oct 29, 2003 | 10:15 PM
jim90gxe's Avatar
No you didn't read the post wrong. What you have is the full rear strut with tokico inserts. Notice the strut how it's a one piece design? You must reuse the stock body. Read this page: http://www.4dsc.com/articles/suspens...ico/rear.shtml.
If you don't believe me remove the gland nut and check the cartridge for yourself. I wouldn't rip you off.
Old Oct 29, 2003 | 11:54 PM
Jack.'s Avatar
It's the difference between insert vs the cartridges right?
Old Oct 30, 2003 | 08:33 AM
KLoWnPR109's Avatar
insert and cartridge are pretty much the same thing
Old Oct 30, 2003 | 03:25 PM
o god... im going crazy
ok, i jsut sent out a PM, to Jim and to N34JZ saying how i got ripped of or somthing..sorry guys im stupid, i should have read this first...
i might be stupid or the rear left strut is blown... cuz it falls down with the spring off and i can move it up and down easly with my hand.
jim sorry about all this im so paranoid buying things from ppl..
does tokico have a good warrenty?
Old Oct 30, 2003 | 04:14 PM
jim90gxe's Avatar
Ya if it just falls down it's blown. Remove the gland nut with a pipe/monkey wrench and remove the cartridge. I just called up tokico and they said the place i bought it from-Nopi- will replace it. Nopi is closed right now but I'll give them a call tomorrow. Or if you don't want to wait I'll split the cost for a new cartridge with you. They go for about $60-65
Old Oct 30, 2003 | 04:36 PM
Jim90GXE is a good guy.. not bad, im so stupid
well its all falling into place.... i hope
all i have to say is.....
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
