View Poll Results: What casued your stalling problem?
Coil packs
40.00%
Injectors
10.00%
Spark plugs
30.00%
Vacuum leak
0%
TPS
0%
ECU/ECM problems
0%
other electrical problem (ex. broken wire, loose connection(s), short, etc)
0%
O2 sensor
20.00%
MAF
20.00%
Other
20.00%
Multiple Choice Poll. Voters: 10. You may not vote on this poll
How did you fix your stalling problem?
Old Nov 7, 2003 | 06:04 PM
Ninty-two-se's Avatar
How did you fix your intermittant stalling problem?
I fixed mine by changing the coil packs... what did you fix/ replace to solve your problem?
Forgive me if I have overlooked another common casue.. Just post it here if you feel it should be mentioned...
Old Nov 7, 2003 | 06:14 PM
AscendantMax's Avatar
i simply put more gas into my car (it was on E, stalled when i pulled into my home).
Old Nov 8, 2003 | 06:26 AM
Nighty93MaxSE's Avatar
My max would almost die, and have the roughest idle when it got warm; I replaced the KS, big coolant temp sensor, pcv, all vacuum lines, fuel filter, spark plugs, and cleaned the intake/plenum/tb while it was out. Now the max has power all of the time, but the idle is still pretty rough, though rock solid on the tach if that makes sense. My front 3 coils all have cracks; per a long ago suggestion by Matt93, I e-taped the fronts temporarily and it helped, but now they have to go- the idle vibration/off idle hestiation has to be caused by that, my slightly outta spec TPS, or my slight exhaust leak (sounds like hole in flex pipe, pray not the exhaust studs!) My injectors ohmed out to 10.8 and 10.9 throughout the whole set, whoot- 135k on the motor
Just sharing some of my findings- I'm going to watch this thread while I save up some more cash to fix this stuff.
Old Nov 8, 2003 | 06:28 AM
D-sta's Avatar
Advanced timing and never again. Next tune-up this summer, the regular stuff, new coil packs and IACV.
Old Nov 8, 2003 | 08:43 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
im putting in a new motor !!!
Old Nov 8, 2003 | 03:55 PM
Gjohnson's Avatar
My stalling was solved by coil packs also, although I did replace alot of other things trying to find the problem.
Old Nov 8, 2003 | 10:21 PM
subs1000w's Avatar
coil packs on old motor, no stalling yet on new
Mar 12, 2020 12:06 AM
97_GXE
Sep 15, 2015 06:47 AM
conansriver
Sep 11, 2015 10:26 AM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
