Handling
Old Nov 21, 2003 | 10:02 AM
maxmvp's Avatar
Handling
About 6 months ago I installed eibach spring, KYB shock and a FTSB on my 89. For the first 3 months everything worked fine. Now if i make a turn to tight, it feels like the car is sliding across the road. I haven't upgraded to 17 yet, but I see why that would be a problem. Does anyone know what could be wrong?
Old Nov 21, 2003 | 10:07 AM
internetautomar's Avatar
mod or sell?
Bald Tires?
Old Nov 21, 2003 | 10:21 AM
cneary812's Avatar
well it could be a number of things... To start, how fast are you going around these turns? If you are taking turns like a mad max man then you may slide. If you take turns like me you might break something Get yourself a good set of tires, and a rear swaybar. That would be what I would do if I were you.
Old Nov 21, 2003 | 10:46 AM
maxmvp's Avatar
It happens when I make a left turn from a signal light. I am usaully not got fast at all. The tire have about 90% tread left on them.
Old Nov 21, 2003 | 10:55 AM
mod or sell?
Are they properly inflated?
Old Nov 21, 2003 | 11:00 AM
maxmvp's Avatar
yes, I check them at least twice a month
Old Nov 21, 2003 | 11:06 AM
mod or sell?
Did you look under the car for loose / broken sway bar parts?
Just thinking
Old Nov 21, 2003 | 11:08 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
left turn from a signal...15...20...25 mph? big problems if you're "sliding" at those speeds
Old Nov 21, 2003 | 11:12 AM
maxmvp's Avatar
I haven't had time to check the uderside. I read that the back sway bar bracket can break if you put new after market swaybars in. Is this true? I was thinking of put the ST sway bars front and rear in. What can been done to prevent this from happening?
Old Nov 21, 2003 | 11:38 AM
cneary812's Avatar
Absolutely yes your stock brackets WILL break so as long as you beaf them up before they break then they won't break. You just need to strengthen the mounts with a piece of steel welded to the bracket by the frame
Old Nov 21, 2003 | 12:02 PM
maxmvp's Avatar
Thanks for the info.
Old Nov 21, 2003 | 12:09 PM
cneary812's Avatar
no problem, I just wish that I knew about it before I put mine on and ripped the brackets out. I made new brackets and bolted them on (ripped one out again) and will be welding them back on next week
Old Nov 21, 2003 | 05:58 PM
Bman's Avatar
Yeah, I would check the suspension for worn out or broken parts. Don't just get down on the ground and look - you should jack up the front of the car (use stands!) and check all the components and bushings. Alternatively you can take it to a mechanic to check since it's easier to do the checks up on a hoist and he can do it faster anyway...
Old Nov 21, 2003 | 07:18 PM
Matt93SE's Avatar
STFU n00b!
probably time for a full suspension rebuild.
by this time, your 89 should have gone through a set of ball joints, tie rod ends, sway bar links, control arm bushings, etc etc etc.
If you haven't replaced any of them, then I can guarantee you the car will handle better if you do.
Old Nov 22, 2003 | 04:12 PM
mod or sell?
Not to mention be safer!
REDinLV
Aug 15, 2024 12:30 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Sep 29, 2015 11:29 PM
zmcneely13
Sep 26, 2015 02:26 PM
