For all of those whe have replaced BOSE
Old Nov 29, 2003 | 02:42 PM
max723's Avatar
I know i should have searched but its been disabled. After i change the HU, can i just switch to a different 4" speaker in the bose pod?
Old Nov 29, 2003 | 04:22 PM
internetautomar's Avatar
mod or sell?
Nope, The pods use a 3 bolt mount versus a 4 bolt more common mount.
James sells 6.5" pods
Old Nov 29, 2003 | 04:24 PM
DMad8724's Avatar
I got 2 4"s for my fronts, the factory are screwed in with 3 screws, my new pioneers have 4 holes, i just bent the hole things and left one and screwed that, fits in there fine, no problems yet...no need to buy pods
Old Nov 29, 2003 | 06:59 PM
87MustangGT's Avatar
Yeah, you can just put new 4"s in there... I did just about the same thing as DMad with my 4" Pios...
However, I would say to upgrade to 6.5s and either buy the pods from James or make your own.
Old Nov 29, 2003 | 07:05 PM
ArcticDC5's Avatar
I just did this whole replacement. What a biatch it was. I ended up running entire new speaker wires from both front doors, wasn't getting a signal and I used james pods with alpine 6.5"s in there. It sounds sweet though.
Old Nov 29, 2003 | 07:36 PM
landjet32's Avatar
converter
I just replaced the head unit with a sony i got from best buy. I kept the bose speakers just wired them through a level converter that I bought at walmart for 15 bucks. Changed over to a universal adapter (also purchased at walmart for about 2 bucks made specifically for bose). Works great. Sounds great. Costs little.
Old Nov 29, 2003 | 10:26 PM
Cliff Clavin's Avatar
Way out West
For temporary (see low on funds) solutions, put 4" speakers in the bose pods or get an adapter so you can have a good HU. However, long term you really should be thinking ahead to 6.5" speakers and making/buying pods.
My car had the stock Bose amps/speakers with an Alpine HU and a Peripheral bose adapter (look at cardomain.com, they are very nice and work perfectly). Over time, the amps and speakers malfunctioned. Bose stuff does not work well with non-Bose equipment. It worked great for about two years. After that, things went downhill. I drove around for several months listening to AM radio on the one (blown) speaker that produced sound.
This is just my advice and I know everyone doesn't have hundreds of dollars to throw at their stereos. Neither did I. Slowly I bought bits and pieces for my stereo until I could finally rid myself of everthing that says "Bose" except the grills. I had the pods from James before I could afford the speakers to go in them. I also have a subwoofer purchased from a pawn shop and an amp that I bought in 1997. Respectable stereos can be had cheap if you are patient and thrifty.
my $.02
Old Nov 30, 2003 | 03:35 PM
icemanhg3's Avatar
WANT GOOD SOUND NOW!!!! (cheaply) BTW Red92MaxSE, can I use your $0.02 to add to mine so I can be that much closer to getting a decent sound out of my stereo???
Old Nov 30, 2003 | 06:42 PM
shoult's Avatar
While several sites have covered changing over stereos, I'll add a link to my page.
http://www.mr2sc.com/MaximaSE/serv02.htm
While I don't cover fabbing up door enclosures or installing aftermarket speakers in the front Bose pods, I do show how to adapt the factory wiring to use a aftermarket head unit with either Bose or non-Bose speakers. This is basically bypassing the separate Bose amplifier located at each speaker. This means you don't need to bother with a rinky-dink "level matching" device. It also means you are free to later add any amps you want to at any point in the wiring.
http://www.mr2sc.com/MaximaSE/Stereo...0connecter.jpg
http://www.mr2sc.com/MaximaSE/Stereo...oseSpeaker.jpg
Old Dec 1, 2003 | 06:49 PM
DMad8724's Avatar
ARTICDC how did you run new speaker wire...i just used the original, but am thinin about running new wire for a clean setup...did you have to rip apart yor dash? any pics? instructions?
Old Dec 1, 2003 | 07:41 PM
ArcticDC5's Avatar
No, you don't have to rip apart your dash, just remove your radio thats all. What I did for the rear is poke through next to the opening on the corners of the seat. Use a coat hanger and tape the speaker wire to it, while you push it through. Then I just tucked the wires under the door jamb plastic trim and it then tucks under the dash. The front however was such a pain, took me 4 hours total. I pulled the door panels off and then used James's speaker pods in place of those sh*tty bose enclosures. You will poke through 2 rubber grommets, one in the door and one in the body. Once you start poking through to inside the body, its tough because there is a lot of wires in your way and you have to find the spot. Thats if the tape does not rip off the coat hanger due to the lack of working space. Then once wires are ran, I just tapped into the correct wires for the cd player wiring harness.
Old Dec 1, 2003 | 11:51 PM
MrGone's Avatar
you can hack the crap out of the stock bose pods.... but really just buy James pods. With my old black maxima I built my own (didnt know James made them). You seriously can't beat James pods for price and quality, and it will save you alot of time (assuming you have all the proper tools in the first place)
Old Dec 2, 2003 | 12:18 AM
davebond007's Avatar
Btw, everyone is reffering to James92SE.
Old Dec 2, 2003 | 12:44 AM
MrGone's Avatar
Thanks mom!
Old Dec 2, 2003 | 12:52 AM
Originally Posted by MrGone
Thanks mom!
Yaaaay
12345
6spd4dsc
May 9, 2022 12:30 PM
Maximeltman
Advance Paint and Body Work
Sep 10, 2019 10:24 AM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
