Alarm keeps on going off for no reason..
Old Dec 1, 2003 | 03:47 PM
simplerx's Avatar
My alarm on my 93 maxima gxe keeps on going off randomly for no reason. It would go off maybe once a day, or 3 times in one hour. Then finally today i had to jumpstart the car cause it wouldn't start..
Could it be the alternator? cause i started the car and disconnected the battery and the car turned off.
btw i don't think this matters at all but the random alarm started after i put in a k&n drop in filter.
-Thanks in advance
Old Dec 1, 2003 | 03:51 PM
rrrfoma's Avatar
-Thanks in advance
If your battery is dead - alarm would keep going on and off.
So ... have your battery checked and replaced
Old Dec 1, 2003 | 04:31 PM
internetautomar's Avatar
mod or sell?
-Thanks in advance
Replace / check the alternator (Yup I sell those)
As you correctly checked if you pull the batt cable and the car dies you've got a really bad alternator. But your dash light should have come on.
Every time your batt runs out of juice the alarm thinks someon has cut the power and responds as if it was being tampered with.
Does that all make sense?
Old Dec 2, 2003 | 12:00 AM
MrGone's Avatar
reminds me of my old black maxima... sometimes I couldnt even get into it.... not that that was a bad thing
Old Dec 2, 2003 | 12:24 AM
nubiannupe's Avatar
OG Maxima.org Member
I can just PICTURE you trying to get into your Max, Shawn --->
Old Dec 2, 2003 | 12:41 AM
MrGone's Avatar
---> runs to the passanger door to unlock so the alarm shuts off.... sometimes it really didnt look good, maybe it was just me though. heheheh
Old Dec 2, 2003 | 12:51 AM
zach_denver's Avatar
-Thanks in advance
If you check your alternator and still have the problem, I would just remove your alarm. Mine use to go off randomly about once a day -- sometimes when I open the trunk and sometimes for no reason at all at 2:00 am etc. If you want to do this, it's easy, just take off the lower dash under the steering wheel (about 11 screws) and pull out the box marked Anti Theft.
Old Dec 2, 2003 | 11:39 AM
Lordrandall's Avatar
Do you have a FSTB? Sometimes the bar will push your hood up enough to cause the alarm to go off.
Old Dec 2, 2003 | 12:41 PM
rrrfoma's Avatar
I don't think that alternator is bad. Mostly likely the battery wouldn't take charge or bad voltage/battery charge regulator (I'm not sure which one maxima has). But I would check the battery first.
Old Dec 2, 2003 | 12:55 PM
Matt93SE's Avatar
STFU n00b!
Most of the time the alarm starts going off after working on the car is because the hood sensor is either damaged, or the hood itself is held up somehow.. when the wind blows, the hood moves a bit and the hood sensor triggers the alarm.
I had this problem shortly after installing my FSTB. the way I got around it was by pulling the hood sensor off and re-drilling the holes so I mounted the sensor about 1/4" farther up on the fender wall. completely solves the problems.
I would check to make sure you didn't have anything stuck in the hood anywhere either- like leave a screwdriver on top of the engine when you shut the hood.. it can cause the hood to deform just enough so it's pushed up and sets off the alarm like I described above.
Old Dec 2, 2003 | 04:51 PM
simplerx's Avatar
I checked under the hood, but didn't notice anything unusual. How does the sensor look like?
Also wouldn't the car dieing after disconnecting the battery be a sure sign the alternators bad? I dropped by a mechanic, and he said if it was the alternator all the lights on the dashboard would come on (said to come back tomarrow to check it out).
I think the best thing to try right would be to disconnect the alarm. btw the alarm that is going off is the alarm that came with the car (anti-theft), not aftermarket. After removing the lower dash is the alarm easily seen?
Old Dec 2, 2003 | 05:52 PM
mod or sell?
Very easily.
Right under the column says antitheft
Old Dec 3, 2003 | 11:28 AM
shoult's Avatar
-Thanks in advance
Can't tell you a THING about your alarm (I HATE those sthings!), but I can tell you your charging system is not working. I haven't looked at the manual, but I would assume that these things have a one peice regulator/alternator so that would be it. Unless your belt is extremely loose or missing!
Old Dec 3, 2003 | 11:30 AM
shoult's Avatar
NOT! He removed the battery from the circuit. The alternator SHOULD have kept it running, good battery, bad battery or NO battery.
Old Dec 3, 2003 | 12:15 PM
rrrfoma's Avatar
may be you are right
but as I mentioned before if battery is "short" (doesn't take charge) it would effect the whole electric system including voltage/battery charge regulator (or whatever it is).
what I said - don't blame alternator right away ...
so check the battery --> ... check the regulator --> ... check the alternator and belt (???)
Old Dec 3, 2003 | 12:23 PM
MrGone's Avatar
regulator = built into altenator last time I checked.
Old Dec 3, 2003 | 12:33 PM
cneary812's Avatar
I will have to disconnect my alarm I am tired of unlocking my doors from the passanger side every time so that the alarm won't go off. The factory alarm is bad news.
Old Dec 3, 2003 | 05:36 PM
simplerx's Avatar
wtf.....
I pulled out the fuse for the Anti-theft, and drove it for around 1 hour. I parked it and drove it out again, and while im driving the alarm starts going off.. soo i took out the relay switch for the anti-theft. Drove the car again 5 hours later, and the damn alarm went off while driving! ;/ Im guessing the alarm is going off because i took out the fuse, and thinks im stealing the car??? Is there a core part of it where i could remove it??? I guess alternator or battery is not the problem?
Old Dec 3, 2003 | 05:57 PM
mod or sell?
UNPLUG THE BOX UNDER the STEERING COLUMN!
kmitchel
Oct 28, 2015 09:46 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
RussMaxManiac
Jan 3, 2001 06:41 AM
RussMaxManiac
Jan 3, 2001 05:40 AM
