What's your Maxima's Fuel MPG?
Old Feb 26, 2001 | 07:18 AM
hclll's Avatar
Hello everybody, I'm a newcomer from China.
My 94' GXE runs around 15 miles per gallon in city. Is that normal or too high? If it is too high, what should I check? Sparkler? tire presure?
Last week I had my GXE inspected at Midas, they charge me $500 for replacing 4 brakepads and 2 front rotors. Do you think it is resonable or not? Was I screwed?
Old Feb 26, 2001 | 08:49 AM
wiseguy's Avatar
My '93 Maxima used to get around 420-450 miles per tank on
road trips, so that'd be 30+ mpg. Lately, I am lucky to get
300 miles to a tank, but that should improve now that I have
replaced four fuel injectors and it's running normally. In
the city, I know you are not going to get the best gas
mileage, but I would expect around 20+mpg at least. Bad O2
sensor, bad PCV valve, fouled plugs, dirty air filter, low
tire pressure, stuck EGR valve (?), weak injectors - all
sorts of things can contribute to bad fuel economy. Check
your tire pressure and take a look at your plugs...
As for the brake job, maybe, maybe not. Rotors are listed
at $68 each at Courtesy Nissan and pads are $56 a set. If
they replaced the bearings, tack on $35 each. It adds up
pretty quickly. My wife wore a pad down to metal on the
right front, but I just replaced the pads and had the rotor
turned (about $6) and everything was fine.
Old Feb 26, 2001 | 02:07 PM
Tom's Avatar
Tom
MPG
I drive about 70% HWY/30% CITY here in the Seattle suburbs and get 24-27 MPG.
15 MPG is pretty low unless you live in Manhattan, NY and perpetually stuck in traffic or in a similar environment.
Old Feb 26, 2001 | 02:13 PM
NYCe MaXiMa's Avatar
hmm
I get less then 13 miles per gallon, I live in NYC but don't hit the heavy traffic area's..... even with mostly highway trips I get no more then 16 mpg.
I am still trying to figure out the cause
Old Feb 26, 2001 | 02:38 PM
primeevil711's Avatar
Re: hmm
Have you tried checking your fuel lines?Distributor?Cooling system?Oil system?
kjlouis
Nov 24, 2018 06:09 AM
stromm
Aug 27, 2015 04:13 PM
Balkins
Aug 12, 2015 06:39 AM
Max Nu-BE
Aug 11, 2015 06:34 PM
maxima297
Aug 3, 2015 12:50 PM
