devil locks
Old Dec 10, 2003 | 09:04 AM
Luv4DSC's Avatar
devil locks
I have a 91 se and the power door locks have gone crazy..One day I close the door and all the doors locked with the keys in it...bad very bad. Then a day or 2 later I unlock the car and only the driver door unlocks so I have to push the unlock button...then it moves it the unlock button not working. So now a 1/3rd of the time the doors will unlock with the key, if they don't a 1/8th of the time the unlock button works, and it locks the doors when you close any door a 1/4th of the time. Any ideas on what has happened I was thinking ecu but I don't really know just the only thing I could think of. Thanks for any help or input.
Old Dec 10, 2003 | 09:12 AM
harrymay's Avatar
i cant really help, but i think its like a solenoid for the door locks that might be goin bad.
im starting to get a problem that weird. whenever the temperature is around 40 or below, my doors will lock. this does it without fail. and my car is in a garage.
Old Dec 10, 2003 | 09:50 AM
Paul89SE's Avatar
Try taking your door panels off and spraying some PB Blaster or WD-40 to loosen up the lock solenoids. It wouldn't hurt to spray it on all springs you see in there, but stay away from electrical harnesses. You probably only have to do this with the front doors.
Old Dec 10, 2003 | 10:46 AM
makeuw3t's Avatar
hey i got the same problem but mines even funkier. its pretty much the same like when you close a front door, sometimes itll lock the doors, whether the cars on, off, keys in or out. the weirder part is that when i use my key to unlock from the driverside, ill unlock it and when my key turns back the the normal vertical position, the locks immediately go back down. then when i try to unlock it again, it will sometimes do it again and again until i guess it finally gives up and lets me in. other times ill turn the key in the door to the right and itll go up and then before i can let the key turn back to normal, itll lock, forcing my key to turn and if i try to hold the key turned to the right, i can feel the lock pushing down and it like stutters up and down trying to lock itself and im here fighting it trying to open it. the only way to cure that one is to let the key back to normal and then try and try again until it opens.
oh and i forgot, sometimes when i close a front door, the locks will lock and then immediately unlock! wth!
damn my car!
Old Dec 10, 2003 | 10:53 AM
medic's Avatar
did u check the door lock timer? maybe the solder connections are cracking - although ususally that just means your locks stop working
Old Dec 10, 2003 | 10:58 AM
Jeff92se's Avatar
I'm needing a caw
When cold, my door will unlock then lock again! What's up with that?
Old Dec 10, 2003 | 11:42 AM
rrrfoma's Avatar
I had a similar problem with a driver's side lock (which is 5 wire one). It controls all other door (lock/unlock).
And I had to take out this solenoid and rebuild it because it got all rusty from inside. Don't forget to lubricate it inside.
It has been working fine since (almost two years now).
Old Dec 10, 2003 | 01:35 PM
Luv4DSC's Avatar
sweet. thanks for the help looks like I'll be pulling the panel. Mine does the key thing too and its getting worse.
Old Dec 10, 2003 | 01:40 PM
BML94GXE's Avatar
Maxima Withdrawl is real
yeah mine do all the mentioned above, but i can get the locks to do the down up again trick year round, the one Jeff92se was talking bout
Old Dec 10, 2003 | 01:41 PM
rrrfoma's Avatar
just be carefull with plastic clips when disconnecting links (it is not summer time outside - so be really carefull and try not to break 'em).
Old Dec 10, 2003 | 03:09 PM
harrymay's Avatar
it did it again last nite, im pretty sure i have some bad connections inthere and thats why they lock when cold. but im too lazy to pull it off and check
Old Dec 10, 2003 | 03:33 PM
Ninty-two-se's Avatar
I have this problem with my car and it has gotten worse since I got the car... The drivers side fights back and refuses to unlock but the pasengers side works everytime... I dont even bother trying to unlock it from the drivers side anymore I just go for the passengers side..
Old Dec 10, 2003 | 05:38 PM
internetautomar's Avatar
mod or sell?
Sounds like my wife's van
good thing she has keyless entry
Old Dec 10, 2003 | 07:40 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
lock timer or short or solenoids are going.
Old Dec 11, 2003 | 05:19 PM
harrymay's Avatar
should the doors lock whenever the battery is reconnected? i was trying to reset my ecu and i noticed that when i reconnected my neg cable, the doors locked, leaving my keys in there, good job i was at home
James92SE
142
Jan 2, 2024 09:23 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
ajahearn
Sep 19, 2015 03:03 PM
johnaschon
Sep 14, 2015 04:29 PM
