2 problems on 1 3rd gen...how nice?? help me out guys!!
Old Dec 15, 2003 | 03:56 PM
Maroon'dMaxSE's Avatar
once again i got another problem/problems
A: while driving i noticed my battery and brake light turned on. Whats up wiht that?
B: Anyone got a key problem or 2? i do....cheq it....my driver door is horrible. i literally fight with my car jus to get it... turning it left n right...jus duznt even budge...my passenger side aint that bad though its ok. my ignition is ok my trunk damn it duznt even recognize my key....but while making a new key at the hardware store...the new key didnt fit either doors or the ignition. he even tried making 2 more keys in the process. DIDNT WORK...now obviously you guys will say get a keyless entry....but what is the real problem? my door lock n ignition cylinders gone bad? an idea popped up in my head though. Ever seen a key off a 93 lexus gs? its hotttt goes in n out smooothly i noticed...laser cut.....now what if i take em out n put them on my car.....what u guys think???? any of you guys out here try it?????? hit me up sum feedback if its a good idea or not...THANX AGAIN
Old Dec 15, 2003 | 04:00 PM
Evil_Twin's Avatar
About the key... My key is kinda like that... The teeth are worn down probably. I heard you could get a new key at the Nissan dealer, but the ones that I went to don't know anything about that... All they know are shadow keys... I would like some help on where to get the new master keys please...
Old Dec 15, 2003 | 04:17 PM
harrymay's Avatar
the fluid in the batt is prolly low, and same in the brake resevoir, check em, might be a problem.
i have the same problem with the drivers side and the trunk
Old Dec 15, 2003 | 04:24 PM
808SE's Avatar
Your aalternator is on the way out. Check that your battery is holding a charge. If it is, replace your alternator ASAP.
Old Dec 15, 2003 | 06:19 PM
Golden Ice's Avatar
My key is stubborn to open the trunk and slightly stubborn to open the left side, but its because of the teeth being worn down..copies can not be better than the original..I have a spare master key around somwhere I'll start using and hang this one up as the spare..the nearest dealer to me is over 300 miles away, so I can't really ask them any questions..
Old Dec 15, 2003 | 07:05 PM
e_is_chillin
Hey man wassup? Sounds like an echo in here. I have the same problem. My quick fix was to get an alarm that opens the doors for me and I access the trunk from inside.
Old Dec 15, 2003 | 07:31 PM
internetautomar's Avatar
mod or sell?
Look in the glovebox for the master key code
and have a new one cut from that.
Old Dec 15, 2003 | 07:37 PM
Evil_Twin's Avatar
Blah... I tried to have them cut from the code... the guy was kinda dumb... he kept offering the shadow key when i told him to cut me a brand new key from the code...
Old Dec 15, 2003 | 07:43 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i dont even see my code, my key opens all doors flawlessly but it wont open the trunk...?
Old Dec 15, 2003 | 09:00 PM
torontomaxima's Avatar
yeah ditto ... my drivers door opens all doors only - not just the drivers door, and my key barely opens the trunk - but not the passenger side...
Old Dec 16, 2003 | 10:16 AM
Cos's Avatar
Cos
I had the flashing lights problem on my 300. More than likely you have a knackered battery. Time to replace me thinks!
Old Dec 16, 2003 | 12:39 PM
mod or sell?
My key doesn't work in my trunk.
The dealer did cut me a new one from my code for $5 so that's a good deal,
Now I gotta copy it
Old Dec 23, 2003 | 02:37 PM
super32's Avatar
Donating member? what the?!
A. Alternator is dying
B. Me too! It's either the key core is getting worn; this I say because I have a seldomly used valet key that is still hard to unlock the driver's door.
Old Dec 24, 2003 | 01:54 AM
nubiannupe's Avatar
OG Maxima.org Member
For most of you, it sounds like the dreaded "valet key vs. master key" drama. Especially with all of our cars being 10+ years old, and with the car passing through other owners before resting finally in YOUR capable hands, it's very likely that you have the valet key. Which won't do diddly for the trunk, as we know.
I guess, in the bigger scheme of things, you could just go get yourself a whole new lock set. But whodaflock wants to do THAT?
Old Dec 24, 2003 | 04:52 AM
Nozama's Avatar
Grumpy old guy
Washed the car the other day and the locks all froze, set the key on the stove for a few minutes and went back outside inserted hot key into drivers door and opened it.
Must have melted some of the old greasy crud out because it works like new now.
Might want to try it.
Old Dec 24, 2003 | 03:30 PM
Maxima NutBag's Avatar
I just had a new key cut at the local hardware store for me... only thing that is occasionally fussy is my trunk keyhole.everything else works flawlessly.
Old Feb 14, 2004 | 04:38 PM
dkris42's Avatar
my key broke in the trunk hole STUPID CRAP.
Old Feb 14, 2004 | 04:51 PM
Aaron92SE's Avatar
NWP Engineering.com
I agree on the answer to A being a faulty altenator. Expect your altenator to die at ANY moment. It will leave you stranded. It's a common problem in 3rd gens with that many miles on it and for some reason the brake light comes on along with the battery light.
But, as said above, check to see if the battery is holding a charge. Check to see if the battery is getting a charge from the altenator. It could be your battery not holding a charge or it could be your altenator not providing a charge. It's one of those two things.
Old Feb 14, 2004 | 04:56 PM
YoU CaNt SeE mE
wait so if it opens the glove box and all doors but not the trunk its the valet key ? the only difference was it diddnt open the trunk ? so the valet key opens the glove box ?
Old Feb 14, 2004 | 06:33 PM
bansheenomore's Avatar
The little tabs in your lock cylinder may be wornout. You can pull them out and have them replaced by dealer or locksmith. You may also have a bad cut key. Have a locksmith read the tumbler and make a new key. I broke off my key in the door and had to get it removed. I had the tabs replaced at same time. It works better than it ever did.
I rarely use the key in trunk,I like the buttom method better!!
Old Feb 15, 2004 | 07:26 AM
RosenKen's Avatar
Nissan will sell you a new trunk lock with a new key that fits it for $50 I think it was. Easy to put in too.
maxipower
Aug 21, 2015 11:10 AM
carlosvq30
Aug 17, 2015 11:32 AM
Hawkeye61
Aug 12, 2015 06:45 PM
kirkhilles
Aug 8, 2015 10:53 AM
