advice plz
Old Dec 20, 2003 | 07:19 PM
Badness's Avatar
advice plz
the o2 sensor housing on my y pipe is cross thread and it won't hold does anyone have any idea's as how i can fix this problem.
Old Dec 20, 2003 | 07:27 PM
male's Avatar
Wrap the threads of the O2 sensor in steel wool, Kinda like you were taping then up with teflon tape. Thread it in there.
Old Dec 20, 2003 | 08:55 PM
internetautomar's Avatar
mod or sell?
Get a new "bung" welded on
or just have a plain old nut with the right threads welded on (JBweld works)
But first you have to remove the old bung.
You may also be able to try a Heli-coil kit
Old Dec 21, 2003 | 01:03 AM
nubiannupe's Avatar
OG Maxima.org Member
If the threads aren't damaged too bad, why not use a tap and die kit and try to rethread it??
Old Dec 21, 2003 | 02:17 AM
bobbydigital450's Avatar
J B weld is the shlt. its like duct tape but better
Old Dec 21, 2003 | 09:43 AM
male's Avatar
JBWELD ghetto but it will work, for a while.
Old Dec 21, 2003 | 10:36 AM
mod or sell?
I was only recomending JBweld to hold in a new bung NOT the o2 as the o2 will NEVER come out if you JB it in
Old Dec 21, 2003 | 10:53 AM
male's Avatar
If you are going to go through the trouble of grinding off the old bung and JB a new one, just cough up the 20 buck to have a shop weld it on. Guys at most shops, particularly franchises, will do alot of quick welding for a little cash. Especially if you grind it off first. Also, if you JB anything that is supposed to be threaded in, just know that this will be the last time you can ever service it. Next time the torch or grinder comes out.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
