View Poll Results: Auto Shift, Power Shift, or Comfort Shift
Auto Shift - Mid-Range RPM Shifting
![](https://maxima.org/forums/images/maxima/polls/bar2-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar2.gif)
![](https://maxima.org/forums/images/maxima/polls/bar2-r.gif)
![](https://maxima.org/forums/clear.gif)
93
54.71%
Power Shift - Higher RPM Shifting
![](https://maxima.org/forums/images/maxima/polls/bar3-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar3.gif)
![](https://maxima.org/forums/images/maxima/polls/bar3-r.gif)
61
35.88%
Comfort Shift - Low RPM Shifting
![](https://maxima.org/forums/images/maxima/polls/bar4-l.gif)
![](https://maxima.org/forums/images/maxima/polls/bar4.gif)
![](https://maxima.org/forums/images/maxima/polls/bar4-r.gif)
20
11.76%
Multiple Choice Poll. Voters: 170. You may not vote on this poll
For Those with Automatics!!!
#81
Always in auto. If I need power I step que gas pedal.
In power and comfort I feel it changes too much gears. I use auto and change gears with the gas pedal. It works better for me
![CaRo is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#83
![rimaximaman is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#85
I had my tranny rebuilt, but first gear still sucks imo. Goes from turtle to rabbit between 1st and 2nd gear switch. Is that normal, or just mine?
![Dirt Rich is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#86
I leave it in power mode, those little 160 horses need all the help they can get. The engine works at its most efficient if it not under high load anyway, short shifting in comfort leaves the car powerless to pass so you have to beat on it more to get it to go, and it lugs the engine for less MPG.
![TWINTRBO is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#87
i dont really notice a difference between the three options regarding the fuel consumption, diving it i notice early shift change and quicker response but that all.
![rowanapps is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#88
I like the power setting so the ratio lets it get a little higher on the lines in case someone tries to jump off the line like they know better than I do. Gas mileagle suffers though so I hardly ever have it set. The comfort setting is cool shifts too soon almost too soon. Regular is just right, getting pretty good MPG, kinda sounds like the Goldilocks story...
!['90maxpro is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#89
Since I started this thread I might as well throw in a little something. If you like to jump off the line or use powah mode alot do yourself and you pockets a favor and buy a tranny cooler. Trust me. Even if you don't use those modes buy a tranny cooler. I've been through three trannies since I started this thread and I now will not drive an automatic unless it's a SMG tranny. Test drove one and fell in love. LOL. Anyways ALL AUTO USERS INSTALL A TRANNY COOLER!!!!!
![Scope is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#90
Originally Posted by 94maxshima
hmm... shifts way too much? Shifts are usually longer so it should shift less, just higer RPM's. And I really don't notice too much of a gas milage differen't between auto and Power. I don't run comfort much anymore because of my near imaginary 1st gear.
Hmm.. I actually noticed it shifting less in power. Because say I'm driving normal and I'm at 30MPH then decide to tromp it. Instead of downshifting from 3rd or overdrive, a lot of times it's still in second. Just my personal expirience...
![Maxima9750 is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#91
I leave mine in comfort because i dont notice a difference in the shift points with the other settings.
![RMTC is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#92
I prefer to stay in Power mode ... keeps the turbo boost ready. I also ensure that O/D isn't on below 80km/h.
![The Max is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#93
mostly power mode .....mostly
when i did vlsd test according to fsm(strangely only in m/t section?)
i lifted car so both wheels can spin and put it in neutral
and they dont spin together is this only for m\t's?(92 se auto)thanks
![maximagician is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#94
I'll go ahead and agree with 94Maxshima... Always seemed like a Placebo switch, haven't touched mine in the 3.5 years I've had my max...
Nate
Nate
![Nates78Ski is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#96
Power , POWER .POWERRRRRR LOL!!
well i'm assuming thhe ECU does its own thing, no matter how u look at it
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![Badman_Maxima is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#97
#98
#100
That switch is one thing I miss on my 4th gen. I used to keep it in auto most of the time but once in a while put it in power.
One thing I like to do now is manually shift the auto and redline every shift.
![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
![bhunter is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#101
![Nod](https://maxima.org/forums/images/smilies/nod.gif)
#102
![brynm is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#103
I have'nt noticed any difference with the switch in either position on my 94 se. However I haven't had it long either.
![datsundesmond is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#106
Dude, Power mode definitely doesn't destroy autos. In fact, it's actually more beneficial as it engages the clutches a little firmer. Comfort mode, on the other hand, is the tranny's worst enemy as the low RPM shifts also equate to softer shifts which results in more slip in the clutches before they finally engage. That is the destructive nature of the design of these trannies. All I can say is, I'm glad I got mine built by Level 10. It's not cheap for us Aussies to ship over a whole tranny like I did but it's damn well worth it and my turbo appreciates it all the more.
#107
Originally Posted by DMad8724
Power-- I read on www.4dsc.com that I'll get better gas mileage for city driving.
![alextothestars is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#108
the switch works on mine; power shifts later, auto shifts a bit lower, and comfort shifts much sooner. power always gets better gas and comfort goes right through it.
i never tested my theory, but i always wondered if the comfort's shifting at a low RPM would cause it to have a lower top speed, since you dont get the full range of top speed out of every gear, etc.
anywho, that concept is why i believe comfort eats more gas...you will be driving at higher RPMS in over drive because of the early shifts from 1st to 2nd to 3rd and into over drive at low speeds. not to mention youll be driving longer at these low speeds and driving at that higher RPM level for that duration. 4 minutes at 2.5/3.0k= 10/12k rpms in 4 minutes, where as 4 minutes at 2.0k= 8k rpms in 4 minutes. 10k rmps is a 20% increase in rpms and 12k rpms is a 50% increase, in relativity to 8rpms.
over drive off is a tad faster, but i dont trust it. it is not very gas friendly at any speed over 30...and come on...how many of us drive that slow ALL OF THE TIME?
just dont forget you left it off if you have swapped out your gauges for a 92-94 se gauge cluster from a manual that does not have an overdrive on/off dumby light.
im pretty sure the auto(DOHC) and all manual transmissions are limited slip (in relation to the 3rd gen maxima)
that being said, the auto(SOHC) have the locking differential. the manual might even be locking, but i know that this is true for the autos.
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
that is the biggest gripe i have, but you have to understand that they werent marketing the car to kids or businessmen going through mid life crisises until 1991/1992 and the locking differential was the slower, family-car idea. the 92-94 SE is the true legacy of a Maxima; with its solid, 3500 pound weigh in, a 190hp/ 190 lbs/ft DOHC engine, a limited slip differential, independent rear supsension, and its practical and attractive interior design, the 3rd generation Maxima started it all. sadly, it kinda ended it all, too, and the 4th gen Maxima received its Motor Trend-adored "Q" DOHC engine, but went through a cheaper construction process due to the bankruptcy which lead to Renault purchasing the company and creating the more "refined" 5th gen/6th gen Maxima...you can't even get the manual transmission in one now!
sorry about the rant. i just love maximas and hate to see the altima (bluebird...of which the maxima was designed to be an UPGRADE of...) surpass the maxima as the 4DSC.
sadly, i think we can kiss the legacy of the maxima goodbye from what im seeing/hearing. when i hear maxima these days, i try to think of the 3rd, 4th, and 5th gen 4DSC and NOT Nissan's 2009 answer to the Cadillac....
#109
Originally Posted by Golden Ice
i usually have mine on auto, somtimes on power..but its NEVER on comfort..
I kinda like my auto, but I'm probably eventually going to do a 5 spd swap when the auto fries itself..
![CapedCadaver is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#110
![Caidwen is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#111
what happens if you disconnect that switch entirely? will it default to Auto? I had taken some of my dash panels out, and only reconnected what i thought was necessary (hazard light, mirror_adjuster/cruise_main/rear_defrost/brightness_control pawl), and then I was like wait... maybe I should hook that tranny controller back up also. I never actually started the car without the switch attached.
Also does anyone know if is there a way to tap the automatic transmission computer to add on some +/- direct shifting ability (perhaps controlled by some add-on buttons or switches that we could mount somehwere)?
#112
One thing I like to do now is manually shift the auto and redline every shift.![wall](https://maxima.org/forums/images/smilies/peepwall.gif)
#113
Originally Posted by cneary812
I used to drive with the auto switch on and the OD on but now my auto is slipping a bit and I found that leaving the OD off and the power switch on it doesn't slip. Go figure? Only use OD on highway now. Seems to work
![nc90gxe is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#114
My theory... is a little different
That's how come I don't get this "you will be driving at higher RPMS in over drive because of the early shifts from 1st to 2nd to 3rd and into over drive at low speeds". My car drops into 45mph at about 1800RPM on level ground in OD, regardless how hard I accelerated, provided the engine is warm. turning it into Power would make your OD rpm higher, by preventing you from shifting into OD until you reached a higher RPM in 3rd, which would require faster vehicle speed, and that added speed would make your OD rpm higher. If your car normally shifts into OD at 30mph, which is, say, 1800RPM in 3rd, and then 1400 in OD, but power makes it hold until 2200RPM, and 1700 in OD, at 37MPH. Those numbers are all made up, btw.
As for gas mileage, power makes sense, because flooring the pedal in a high gear uses more gas than babying the pedal in a low gear, and power lets it downshift sooner, which means you don't have to floor it to get the same acceleration. However, at cruising speed, if you are forced to use a lower gear, the added inertia and driveline friction that you have to overcome in a lower gear is why you are wasting gas. I'm pretty sure that coasting downhill in OD uses no more gas than coasting downhill in '2', becuase you're at idle-throttle. The engine isn't trying to spin but about 700RPM, and it's the momentum of the car that is causing it to spin, not the fuel. So therefore, when trying to maintain your speed on a slight downhill grade, you can put it in Neutral, and let the car hold its speed (gravity cancels tire/bearing friction), whereas the engine braking (even in OD, there is a little bit) would make you give it a little bit of gas to keep it from slowing down.
So the sooner shiftpoints of Comfort will give your engine more resistance in the higher gears, causing you to use more gas to achieve the same acceleration. But once you're in OD, you should notice no difference (no more gears left), and if you're flooring it you should notice little difference (no room to use even more gas pedal).
But seeing as how it says I'm a newbie, anyone feel free to prove me wrong, since I know that a lot of you know a lot more than I do.
#116
![](http://bbaparts.com/images/vgatshift.bmp)
That answer your question
#118
not sure what the last column is.
and yes the question was directed towards you, though it is rhetorical
Maybe the last column is an idiot-proof system for those who grab hold of the shifter and downshift with that, where even if you miss 2 and end up in L, it'll hold 2nd until it's safe to downshift into 1st, to prevent over-revving. Just a thought, based on something I read today by Tom and Ray from Cartalk. Because when I videorecorded myself going 0-70, I hit 5500RPM in 1st, right at 40mph, which is exactly what it seems to say in that last column. So if you're going 70 full throttle (or half throttle, according to the chart) and manually shift into L, it ought to ignore your downshift request until after your car has slowed to the 35-40MPH range.
#119
Hey all , I need a little help here . I'm looking into buying a 92 maxima with the v6 auto , but it has a bad tranny . I have found a 95 local that will part with the tranny cheap . Will it work. Sorry to Hijack , but being new I cant start a new thread or I would. Any help would be awesome , I'd really like to buy this one but I need to know what auto trannys are interchangeable. Thanks Corbit.
![Corbit is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
#120
don't thread jack!!!!
![DanNY is offline](https://maxima.org/forums/images/maxima/statusicon/user_offline.gif)
Andy29
09-29-2015 05:32 AM
