brake light!
Old Jan 5, 2004 | 04:49 PM
DMad8724's Avatar
brake light!
ok all the sudden my brake light has been going on and off as it please, usually stays on for a min or two then goes off, what could be wrong?!
Old Jan 5, 2004 | 04:52 PM
todamax's Avatar
Have you checked the brake fluid?
Old Jan 5, 2004 | 04:53 PM
DMad8724's Avatar
does the fluid need to be replaced, refilled everyone once in a while? or could it be leaking, the other day i tried to have a guy put a hole in my firewall but he couldnt, maybe he hit something?
Old Jan 5, 2004 | 04:57 PM
todamax's Avatar
Brake fluid genrally doesn't need to be replaced. The Master cylinder is the big round thing on the firewall infront of the driver. You should be able see leaks if they are there.
ABS or no? (not sure what year that became available)
Old Jan 5, 2004 | 05:01 PM
internetautomar's Avatar
mod or sell?
Umm... that is incorrect. It should be changed every couple of years or so but nobody does it in the US.
Old Jan 5, 2004 | 05:10 PM
todamax's Avatar
Ok, well... I'll rephrase: Here in the US, very few people know that break fluid should be changed. So, given that this doesn't seem to cause mass issues, I bet thats not your problem.
Old Jan 5, 2004 | 05:11 PM
Walka's Avatar
blinker fluid maybe?
walka
Old Jan 5, 2004 | 05:28 PM
DMad8724's Avatar
no abs, yeah the guy was puttin the hole around the master cylinder, i hope he didnt poke a hole!
Old Jan 6, 2004 | 04:11 AM
DMad8724's Avatar
so how do i check my brake fluid?
Old Jan 6, 2004 | 09:13 AM
AscendantMax's Avatar
just look at the level of brake fluid in the master cylinder's reservoir. if low, just add more.
Old Jan 6, 2004 | 12:24 PM
DMad8724's Avatar
ok but if its a leak, then wont it keep leaking? so how do i fix the leak
Old Jan 6, 2004 | 12:34 PM
i doubt it's leaking badly. you said the brake indicator light goes on and off right? it's most likely that the brake fluid is little low. once the fluid gets below a certain level, that light will light up. the fluid can be sloshing around as you drive and the senor will think 'oh it's full' or 'fluid is low'...and will light the indicator accordingly. try adding more brake fluid and see what happens.
Old Jan 20, 2004 | 07:23 PM
jkmay01's Avatar
Lil 8
make sure the sensor in the top of the cap is seated properly, if you had a leak in ya master cylinder u would know your pedal height would be low and mushy would seem like u would have to put ya foot to the floor to stop the car. what is ya pedal height? also you would see a slightly clear very slippery fluid on the ground under ya car the lines coming from the cylinder are steel anyway, just run ya hands around the lines and the cylinder to see if it is wet also check the visual level also.
Old Jan 21, 2004 | 04:59 PM
StRacer718's Avatar
The first thing you should have done when the light came on was check the fluid level for the brakes.
Old Jan 22, 2004 | 08:40 AM
89maxSE's Avatar
see if your E-brake is coming up and down....I have that problem w/ mine :-D But I honestly doubt that is the problem
Old Jan 22, 2004 | 02:05 PM
medic's Avatar
if you refill the fluid and it gets low again, then you have a leak somewhere. it could be calipers or it could be somewhere else, a shop can take a look and let you know. replace whatever is leaking and you'll be happy.
Old Jan 22, 2004 | 03:59 PM
Seyath's Avatar
Checking the fluid is your best bet. Check around the tank and feel around the engine for wetness. Also look for spots when you leave your car parked. Run all of these yourself before you bring the car to the mechanic and he charges you a stupid amount of money just to refill your tank
Old Jan 22, 2004 | 10:20 PM
xveganxcowboyx's Avatar
I thought the E-brake was all mechanical. 89, maybe you just need to tighten your cable.
Old Jan 23, 2004 | 06:16 AM
mod or sell?
there is still a switch to activate the dash light
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
