Addco RSB owners
Old Jan 10, 2004 | 01:02 PM
Jack.'s Avatar
Addco RSB owners
So it finally happened... The rsb supports with the u-bracket disconnected from the pos L-bracket attached to the car. Ripped right out of the hole rather than ripping the entire L-bracket off...
I knew this would happen but didn't realize how quick. Many say to weld on a thicker steel L bracket to it and use that. Which method did u do?
Old Jan 10, 2004 | 02:15 PM
Matt93SE's Avatar
STFU n00b!
Stay tuned for more parts from BlehmCo....
Old Jan 10, 2004 | 05:08 PM
MaDMaX024's Avatar
i got some extra L brackets from addco..soon enough they'll be welded on. just over 3000 miles since i've installed the bar and on endlink broke, the otherside ripped out of its bracket...they've been broken for about 2000 miles!
Old Jan 10, 2004 | 05:15 PM
davebond007's Avatar
Hurry up. I get my bar on Monday!
Old Jan 10, 2004 | 06:28 PM
Jack.'s Avatar
Yeh for real, i can't drive too long with this boat feeling and this clanking noise whenever i turn.
Old Jan 10, 2004 | 06:43 PM
Matt93SE's Avatar
STFU n00b!
I'm going to start on them next week, don't worry.
Old Jan 10, 2004 | 11:18 PM
Torres's Avatar
hey Matt
remember 2 sell me a set of the new brackets...... with the ground kit......and can anyone answer me this question?
can i paint the RSB and it won't affect nothing with the poly bushing???
i don;t want the RSB 2 rust up here in Canada
Old Jan 10, 2004 | 11:46 PM
blackandwhite's Avatar
To them I'm like an idol
I got the welded on brackets. Works fine.
The bracket I used is similar to the one that is used to bolt the endlinks to the hub. I had them welded slightly behind the stock bracket position, allowing the endlink to be nearly perpindicular to the bar
Old Jan 11, 2004 | 02:17 AM
Bman's Avatar
I have an idea on page 4 of my homepage too, if anyone wants to take a look at it, but Matt seems to have something better in store. No hints as to what it is yet though....
Still, Matt did say that my idea should work, and it can be something you do locally if you have welding available, but you're still going to have to scrounge a second link and some metal plate...
I'm pretty sure you can paint it (I did...) as the RSB comes in either a gold anodized or black painted finish.
Old Jan 11, 2004 | 02:49 AM
MrGone's Avatar
Brian, I've been meaning to tell you, your idea works great for one of the link thingys, but the other one has bolts going the other direction, so you couldnt weld the triangles to the top of the bolt.
blah blah blah, I still like the idea
Old Jan 11, 2004 | 03:24 AM
Jack.'s Avatar
Well Matt, as tempting as your offer does in fact sound, I am a bit on crunch for time and money. I'm not sure how long I can handle this titanic feeling on every turn/the clanking against the undercariage on every pothole, especially with these new springs and struts. And if they are worth me waiting, how $$$much$$$ are they worth waiting for?
Old Jan 11, 2004 | 07:43 AM
Matt93SE's Avatar
STFU n00b!
for the time being, just take the whole RSB off and drive without it. (and slow down for the corners!!).
as for price, I'm not sure an exact number yet, but it's looking to be around $40 for the set. I need to get the parts made, then I'll have an idea. I'm going to start on them Monday. should have a real number by tues or so.
Old Jan 11, 2004 | 10:34 AM
Jack.'s Avatar
Sweet sounding, i'll dismantle the beast soon then.
Old Jan 11, 2004 | 02:00 PM
Bman's Avatar
LOL You know, MrGone this is the second time you've mentioned this to me, and I went back to read my page, and found out I already DID mention the fact that you would need to get a second link... (read the paragraph underneath the picture).
....and I also mentioned that again in my above post too....
Old Jan 12, 2004 | 12:59 AM
MrGone's Avatar
oops
edit: or.... ooorrrrrr..... you could have edited that in
Old Jan 12, 2004 | 08:57 AM
Lordrandall's Avatar
Old Jan 13, 2004 | 08:30 PM
Bman's Avatar
No, no... I wouldn't do something like that. I tried looking at the page properties, but for some weird reason it only shows the current time....
Old Jan 13, 2004 | 08:39 PM
MrGone's Avatar
na Brian, it was my mistake, I didn't completely read all the way threw it I just kind of skimmed and got the idea.
me
Old Jan 13, 2004 | 09:10 PM
Matt93SE's Avatar
STFU n00b!
These are some crappy pics of the first one I made.
You'll notice there are two different heim joints on there... For the "production units," I've ordered a female joint with a stud in it- basically a blend between the two. Unfortunately I didn't have any on hand when I made this piece. I've ordered some and they should be here by Friday.. I'll clean it up and post more pics then, but you can see what this part amounts to.
It will include the angle iron piece and the self-tapping screws that go into the frame rail. just use a hacksaw, grinder, whatever to cut off the old one, then install this one by drilling two small holes into the frame rail and screw the self-tapping screws in and it's mounted! If you wish, you can take it to a muffler shop and have them weld it onto the frame.
Honestly, I wouldn't worry about that though, as I've had the same thing holding my RSB links on the car for two years now and no problems.
Anyway, here's the pics. Again, please excuse the old-school Heim.. it's the only female one I had in the garage at the time.
http://www.mattblehm.com/HSS_images/...rsb_link_1.jpg
http://www.mattblehm.com/HSS_images/...rsb_link_2.jpg
http://www.mattblehm.com/HSS_images/...rsb_link_3.jpg
Old Jan 14, 2004 | 05:37 PM
Jack.'s Avatar
sweet looking, even if these are prelim photos... I'm interested.
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
Forge277
Jun 13, 2016 09:26 PM
bernyp
Oct 2, 2015 10:10 AM
