unothodox UDP
Old Feb 1, 2004 | 06:12 PM
jaemax's Avatar
unothodox UDP
when the oe UDP is replaced w/ the high performance UDP.. is it still posiible to run a system or would a lightning cap be needed to run the system once the aftermarket UDP is implemented....
jaemax
Old Feb 1, 2004 | 06:38 PM
xveganxcowboyx's Avatar
I think you only need a cap if the system is really big. With an under drive pulley I think our cars are putting out 60 amps??? at idle and more when revved. My civic only had a 60 amp alt and pushed 3 jl 12's w/ almost no dimming of my lights w/ everything else on. (not a really huge amp, but good enough)
BTW if you haven't already gotten a new UDP you should just buy a stock sized lightened one. Most of the power gain comes from the reduction in weight, not the underdriving.
Old Feb 1, 2004 | 07:40 PM
jaemax's Avatar
thank alot man... where can i purchase a lightened UDP from? second thing regarding lights dimming... i already have that problem on occassion.. i have noticed that my lights get brighter when i give the car gas and i just bought a new battery the optima blue top for real cheap and it still dims every now and then... what can the problem be... thanks
jaemax
Old Feb 1, 2004 | 08:38 PM
todamax's Avatar
I've got a UDP and am pushing about 500 watts. If I'm pushing it hard, the lights will dim a bit.
Old Feb 1, 2004 | 08:52 PM
Jack.'s Avatar
Yeh i had this question too... if i have a RF Punch pushing 740 bridged and a 4channel sending 75W/channel will i end up needing a cap too?
Dave B
May 29, 2001 11:07 AM
y2kse
Feb 25, 2001 08:47 PM
Andrew91SE
Nov 26, 2000 03:05 AM
ohboiya
Oct 9, 2000 12:23 PM
