VG engine knock sensor
Old Feb 2, 2004 | 10:36 AM
tmuscedere's Avatar
Does the problem with the knock sensor only apply to VE engines. Or does it apply to the VG engine as well?
Old Feb 2, 2004 | 11:29 AM
mtcookson's Avatar
just the ve engines that i know of. if i drive a lot i notice a little bit of heat soak on mine, but nothing to worry about. when i first start driving my car my s-afc will read 0 on the knock but the longer i drive it will start raising a bit. when i did an 8 hour drive i think the highest it got was around 20 so its not all that bad. i think bad knock on the s-afc is in the hundreds. so, you shouldn't have to worry much around heat soak on the vg.
Old Feb 2, 2004 | 11:41 AM
Tarzan's Avatar
Thanks for the info that I was also interested in. I did a check on my VG knock sensor recently and found that it was sending clear signal at 11 years old and about 100k miles, but still was not sure if the problem applied to my car.
Old Feb 2, 2004 | 12:00 PM
tmuscedere's Avatar
thanks for the info. Just wanted to know if I should replace it while doing the fuel hoses.
Old Feb 2, 2004 | 02:05 PM
-shock211-'s Avatar
7890
Old Feb 2, 2004 | 06:08 PM
harrymay's Avatar
matt sells a ground kit for the vg also, its supposed to kill some of the heat soak, i think, but its good for the tranny
mvm062
Nov 30, 2020 09:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
03VQMAX
Sep 5, 2015 03:47 PM
dcardello
Sep 3, 2015 11:44 PM
