Fot those with the Addco Rear Anti-Sway Bar
Old Feb 12, 2004 | 10:45 AM
94M@X's Avatar
Are the urethane bushings always red? I recently purchased one through a GD and have had some trouble with the bushings. The first set was a red firm plastic like material but they sent the wrong sizes. After making arrangements with the vendor to have replacements sent, I received black rubbery like brushings that smelled like rubber. Am I right in assuming that the black brushings are not the optional urethane bushings? I don’t know anything about urethane.
Gil
Old Feb 12, 2004 | 10:50 AM
Jeff92se's Avatar
I'm needing a caw
Mine were red and very solid. Looks like you got a set of stock rubber bushings. Ask for the urethane.
Old Feb 12, 2004 | 10:52 AM
Matt93SE's Avatar
STFU n00b!
yeesh.. call 'em up and gripe at 'em again.. you shouldn't be using soft rubber with that bar. too much give. urethane is a must. they should be red (from energy suspension, btw)
Old Feb 12, 2004 | 11:24 AM
94M@X's Avatar
Thanks I just sent Brian at Cattman Performance an email (GD was through them) to please have Addco send the urethane brushings. Addco had already messed up twice with this order?
Old Feb 12, 2004 | 12:39 PM
Jeff92se's Avatar
I'm needing a caw
Instead of waiting, you could just go down the the local autostore and dig for the right ones. I know you "SHOULDN'T" have to pay for the correct stuff but it's not that expensive and you could probably have the bar on weeks faster. Prinicple vs reality I guess.
Old Feb 12, 2004 | 02:32 PM
ChrisCheezer's Avatar
now get a set of Matt's upgraded rsb links..
matt will have them shipped to u in NO TIME
-once that sway bar goes on.. and u start wip'in it around turns at 120, thoes link will last maybe a month.. get thoes link before its to late,and u have to sit around ur house and look at the wall all day long, cuz ur rsb is hanging on with zip ties and bubble gum
- I also recived wrong parts with my addco kit... the bolts were very wrong. they didnt even look close.. i baught the right ones at a local hardware store..
Old Feb 13, 2004 | 04:38 AM
Tim93se5sp's Avatar
The bushings I received with my addco were black also. After a few weeks they started squeeking pretty good, so I only assumed they were urethane. I have since quieted them down, but would like to know if they are the correct (urethane) ones. Anyone else receive black bushings? Or are all ES bushings red?
Old Feb 13, 2004 | 05:42 AM
Matt93SE's Avatar
STFU n00b!
ES also has their graphite impregnated bushings which are dark grey/black in color.. but they're going to be hard just like the red ones. if theyr'e soft rubber, then they sent you the wrong stuff.
Old Feb 14, 2004 | 11:34 AM
Bman's Avatar
It's hit and miss sometimes with Addco. Apparently there are supposed to be two types of sway bar kits they can send you. One with rubber bushings all around, and another with urethane ones.
When I got mine I got a wierd "hybrid" set with rubber endlink bushings and urethane bar bushings. I decided not to persue the matter...
Old Feb 14, 2004 | 12:05 PM
Tim93se5sp's Avatar
Mine were definitely hard- sure didnt seem like rubber to me. I guess I got the right ones.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
