Might be a played out question but... 6x9s in rear deck???
Old Feb 17, 2004 | 12:43 AM
COChev's Avatar
i have a non bose system and i just put in a new head unit and 4x6s in the doors. any reason why i can't stuff 6x9s in the rear deck. i see that i will have to cut back some metal, but i have the tools of destruction for that
i want to cut them in and then put the gay "active speaker" covers back on for the stock look. out of sight out of mind.
Old Feb 17, 2004 | 12:48 AM
Michael's Avatar
Back in a 3rd Gen.
I wouldnt even cut the deck. I would go to a junk yard and pick up a pair of bose brackets. The bose had 6x9 in the rear and that bracket will just bolt right up to your deck without any mods at all. best and cleanest way to do it.
Old Feb 17, 2004 | 05:28 AM
COChev's Avatar
not a lot of 3rd gens in my area and even fewer at the junkyard. it doesn't look to be to tough to cut in. a jigsaw with a metal blade should do the trick. most likely going to do this tonight after work so i'll post up and let you know how it goes.
Old Feb 17, 2004 | 05:48 AM
Michael's Avatar
Back in a 3rd Gen.
its not that its hard but its that I wouldnt want to butcher up the rear deck. You also may have clearance issues with the torsion bars that hold the trunk up (they run right under where the speakers are). Its your car though so if you dont mind cutting it then go ahead (I am being honest here not sarcastic).
There are a lot of people on here that have wrecked their car and are parting out...you can probably find the brackets for cheap from one of them.
Old Feb 17, 2004 | 06:09 AM
COChev's Avatar
so whats the deal with the brackets then? do they allow the speaker to be mounted from the bottom instead of dropped in from the top? either way, wouldn't the hole in the deck need to be big enought to accomodate a 6x9? thanks,
jason
Old Feb 17, 2004 | 06:25 AM
internetautomar's Avatar
mod or sell?
They are bottom mount speakers.
And there is plenty of clearance IMHO for any set of 6x9s to be mounted
Old Feb 17, 2004 | 06:36 AM
Cliff Clavin's Avatar
Way out West
Yes, they mount from the bottom. Stock bose systems have 6x9s, so the brackets are made for the speakers to fit perfectly in that location, underneath the parcel shelf (so everything looks totally stock). Even on Bose cars, the size of the hole in the deck doesn't allow for top mounting of the speakers without cutting.
It actually sounds very good. I have Infinity Reference 6x9s (under the shelf, as I had bose originally) and I didn't cut my deck.
Cardomain doesn't seem to be working right now, but I have pics of my system on my cardomain page (www below the signature). If you look above my Eclipse sub, you will see my 6x9 above it. I will try to take better pics if you want to see what it looks like.
Old Feb 17, 2004 | 07:02 AM
xveganxcowboyx's Avatar
I have the brackets and the whole rest of the bose system for sale.
Old Feb 17, 2004 | 04:18 PM
MaDMaX024's Avatar
why bother with all the trouble? just get 6.5"s and be happy...to each his own i guess.
Old Feb 17, 2004 | 04:54 PM
COChev's Avatar
i have 6.5s and they are the 6x9s are going in tonight. i'll post up when i'm done and let you know how much of a pain it was
Old Feb 17, 2004 | 05:19 PM
MaDMaX024's Avatar
6x9s are alot boomier and very much less defined than any 6.5 i've had experiance with..speakers like that ARE NOT MEANT for bass, get a sub for that...like i said, to each his own
Old Feb 17, 2004 | 10:28 PM
COChev's Avatar
no worries, man. i still want a sub too. just like a little more mid range from the back. the 6.9s went in with a little freindly trimming from the sawzall. a little more trimming on the underside of the factory speaker covers and it all went back on looking stock. now all i need is a small amp and a sub in the trunk.
Old Feb 18, 2004 | 06:37 AM
Way out West
Darn, I just sold a JL 10w3...and you are pretty close, too.
Sounds like it worked for you without the brackets. You should take pics for other guys with non-bose systems. It might be helpful in the future.
Old Feb 18, 2004 | 06:54 AM
bennett's Avatar
give it a try
I ripped out the Bose and replaced the rear speakers with 6x9s and they fit perfectly. If you're having trouble fitting them into your non-Bose setup, I would assume that the Bose bracket would fix the problem. I can't believe that the size difference between Bose and non-Bose mounting areas could be THAT big, but keep the reciept just in case!
Old Feb 18, 2004 | 03:28 PM
89badmaxse's Avatar
damn all that cutting and i have extra bose brakets sitting in my room........
Old Feb 18, 2004 | 03:49 PM
drakken789's Avatar
what speakers will fit in the doors on a bose system?
Old Feb 18, 2004 | 04:02 PM
MaDMaX024's Avatar
back in the day, i dremeled out my pods to fit 5.25" coaxs, but you could probably squeeze a 6.5 in there..i just made plates for my 6.5"s it was easier at the time.
Old Feb 18, 2004 | 04:09 PM
drakken789's Avatar
sweet thanks
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
Mcnabb34
Aug 11, 2015 08:45 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
