Oily residue in intake manifold normal?
Old Feb 27, 2004 | 04:50 AM
89sks's Avatar
Just got my upper intake manifold off my 89 VG and noticed a lot of oil and grime in there? I have also in the past noticed a bunch of oily stuff that had collected where the breather hose connects to the air intake right before the Throttle plates. I have cleaned it out when I cleaned the TB and I put a new PCV valve in a long while back and have changed it regularly.
Anyone else experience this, is it normal or do I have a problem?
Old Feb 27, 2004 | 05:07 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
sounds normal...mine was oily and dirty too
Old Feb 27, 2004 | 06:30 AM
89sks's Avatar
Phew, thanks! I cleaned it off as good as I could without letting the crud fall down into the intake further. Im also trying to get the old gasket off using the gasket remover but its not working so well.
Thanks again.
Old Feb 27, 2004 | 03:05 PM
bonzelite's Avatar
mine was same as well. i chalk it up as not cleaning air filter enough. my fault.
Old Feb 27, 2004 | 03:25 PM
MrGone's Avatar
PCV plus those valve cover breathers, actually I think the valve cover breathers contribute it the most. The EGR area is baked on lol.
Old Feb 27, 2004 | 08:00 PM
Psubird83's Avatar
Its blow by, either A you have a dirty pcv valve B a bad gasket or C burning oil fried rings, I wouldn't get to worried about it if it has been there for awhile, just keep checking your oil
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
