Misfire in my VG
Misfire in my VG
About two weeks ago I changed my plugs from Bosch platinum to NGK V power.
Now, I'm not sure if it happened right after or this could be the cause of another thing but my car has been misfiring. I changed the cap and rotor and the wires are in the mail and will change once they arrive.
Has anyone ever experienced any problems with either changing to NGK V power or any new plugs? Should I take them out and put them back again? Should get another set just to see if the plugs are the problem?
thanks guys!! :attention
hes saying that when you changed the plugs you just pulled all the wires off at one time and not individually, and had you pulled them off one by one then you wouldnt have a misfire...the OE wires are number, go double check and make sure they are all going to the right cylinders
Originally Posted by Seyath
Check you fuel injectors, your wires (probably not a bad time to upgrade), and your spark plugs. Maybe you didn't gap them or set them in properly.
This just happened to me. I mentioned it on another thread. I had just fixed the rear manifold (it had pulled away), put in a new: gas filter, pcv valve, o2 sensor, air filter ,etc. The front exhaust manifold had pulled away, too and still leaked. But after all of that there was no misfire. I then changed the cap and rotor and put in non-platinum autolite plugs (don't ask me why I was being cheap at the time), which replaced the ngk-v's. Now I have a misfire.
I thought maybe I was getting better detonation and it threw off the new o2 with the exhaust leak. So if fixed the front manifold (Later, I'll do a write up on exactly how to fix broken studs without pulling the heads) leak. Now, I don't hear any exhaust noise (hallelujah chorus), but I still have a misfire (sigh). Tonight I'll go trough the trash and find the plugs I threw away and see if that fixes it.
oh, I also made sure they were gapped correctly. I also checked the timing which is dead on 15 degrees.
jmlee44
10-02-2022 02:13 PM
ballerchris510
09-11-2015 05:29 PM
