simple offset question
Old Mar 4, 2004 | 09:50 AM
wicked_ryder's Avatar
hey guys, just a quick question that i know prolly has been covered 1000 times...but i'm gettin rims, 17x7.5 with 45mm offset...will this offset work??? i just wanna make sure. thanks in advance!!!
Old Mar 4, 2004 | 10:06 AM
Jeff92se's Avatar
I'm needing a caw
Not with 295-25-17 tires
Old Mar 4, 2004 | 10:07 AM
Matt93SE's Avatar
STFU n00b!
it'll be close, but it should work.
I used 17x8 w 34 offset...
a 17x7.5 w/ 45 offset will sit as far into the wheel well as a 17x8 w/ 32 offset.
Old Mar 4, 2004 | 10:11 AM
cool, i'll prolly just use 215/45/17 tires
Old Mar 4, 2004 | 10:19 AM
Jeff92se's Avatar
I'm needing a caw
WAY too small. 225-50 or 215-55
Old Mar 4, 2004 | 10:26 AM
really...too small....cuz i've got it lowered right now, an was told i'd need 40 series tires....got s.t. springs an kyb struts holdin it down now.
Old Mar 4, 2004 | 10:34 AM
Jeff92se's Avatar
I'm needing a caw
Uh it doesn't matter. Don't go down rice alley and get tires that are way too small in diameter.
Old Mar 4, 2004 | 10:46 AM
Matt93SE's Avatar
STFU n00b!
whoever told you that should never recommend tires to anyone.
use the proper size tires and you won't have a problem.
if you want 45 series sidewalls, you'll have to go with a 235 treadwidth to fit properly.
(which the 235 may be too wide for a 7.5" rim, not sure)
Old Mar 4, 2004 | 02:45 PM
Bman's Avatar
No, 7.5" is the lower limit for 235/45 size tires, so they'll work, but then you'll rub.
Don't worry about the sidewall height looking too high, if that's what you're worried about, because it will be identical between 215/55 and 235/45 because it's a percentage. 215/45 is way too short.
Old Mar 4, 2004 | 09:36 PM
Matt93SE's Avatar
STFU n00b!
You won't rub... I'm running 235/45/17 on mine now. 17x8 wheels.. 32 offset on the rims I'm using now, 34 offset on my previous set both fit fine.
Old Mar 5, 2004 | 08:16 AM
Lordrandall's Avatar
235/45-17's on a 7.5" wide wheel with a 45 offset will rub in the back.
Old Mar 5, 2004 | 12:28 PM
Bman's Avatar
Yeah I just meant in this case his wheels would rub. I remember when Mr.Rose and James were trying to fit those Subzeros (which have identical specs to the wheels he's asking about) on their cars and Mr.Rose, who was trying to fit 235's, was encountering rubbing. Can't remember if that was in the rear only or both ends though....
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
