Where Can I Run A Wire Through The Firewall ?
I was going to drill a hole through the firewall below the brake booster so I can run a gauge wire from the battery but my friend told me there should be a hole in the firewall where I could just run some wire through and not have to risk drilling into something or mess it up in some way. Anybody ever done this successfully or find a opening to use ?
i drilled me a lil hold right infront of and to the left of the gas pedal if you were looking at it from the inside then ran it under my center console, across to the DS underneath the carpet (under the seat) and then back to the trunk from there.
i drilled a hole too - powertools and me - bad idea - but it came out great. Just drill a hole - nothing going to happen, just make sure its clear of anything else on the other side.
O and one question do u have a security system if so who ever installed it prolly drilled a hole threw the firewall - so um u can pass the wire threw there.
As much as I like power tools, I dont like drilling on the car unless I have to. Plus going the route that vegan, rey, and I did it automatically hides the cable in the fender. I ran my 4gauge threw the hood release cable grommet without a problem and have run countless 8gauge wires threw, easy, fast, and best of all no drilling.
Btw man, I love the whole "blacked out" look...have you thought about gunmetal wheels? I think it would go better w/ the car, but thats just my .02
Keep up the good work
Originally Posted by BensMax93
excuse my newb questions but:
-How would I go about removing the splash guards?
-Where is the "hood release cable"?
thanks
thanks
Wheres the cable?-
Originally Posted by MrGone
Originally Posted by turdlett
I was planning on doing the same thing but for now I have blacked out my clear corners.
They are completely blacked out??? wouldn't that take away the whole purpose of having the corner lights. And if you were gonna black 'em out, why did you get the clear corners instead of just using your factory lenses?
The Frye
09-02-2021 11:03 AM
ballerchris510
09-10-2015 09:35 PM
