A/C on a 91 GXE Max... problems...
Old Mar 8, 2004 | 01:28 PM
Panzer's Avatar
Hi all,
I just noticed that my A/C isn't working anymore. Was doing good last summer, fall and even some times this winter when it was not too cold. We had freezing weather recently so I didn't use it...
Started it up yesterday, no drop in the rpm, seems the compressor isn't starting, and the air is not cold at all. All the hoses should be ok. I cheked the fuse, ok.
I'm thinking maybe it's because there's not enough R12 in the system and the low pressure sensor is preventing the compressor from starting.
Big question : Is it possible to convert to the new gaz (94+) without replacing all the expensive hoses ??? simply changing the oil type in the system ?
thanks,
David
Old Mar 8, 2004 | 01:53 PM
internetautomar's Avatar
mod or sell?
all you need is to have your system evac first. then get the new fittings, install them and charge up with the new stuff and oil.
tarun900
19
Dec 20, 2021 06:57 PM
homewrecker
Sep 24, 2015 07:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
EdRomo86
Sep 12, 2015 07:49 PM
