levoc installation
Old Mar 9, 2004 | 12:11 PM
max723's Avatar
levoc installation
i wanted to install a levoc shift **** but noticed on chris91se's, the **** sits up a little and isnt flush with the bottom of the shaft. it looks like the **** isnt pressed down all the way. is there a way to cut the stock lever so that the shift **** is flush when installed?
Old Mar 9, 2004 | 12:53 PM
harrymay's Avatar
just buy an sts, that would work better, unless your an auto
Old Mar 9, 2004 | 01:29 PM
Gjohnson's Avatar
I think he is talking about an auto. Right???
Old Mar 9, 2004 | 01:50 PM
max723's Avatar
yes, an auto
Old Mar 9, 2004 | 03:01 PM
Michael's Avatar
Back in a 3rd Gen.
yes there is...I did on mine. The problem you run into is that the rod is way smaller than the tube that it is in. There is the white plastic piece that keeps it centered but if you cut that you will have to have something else center it. I happen to find a piece of rubber that looked like it was a protective tip of some type. Anyway I used it because it had a hole just the right size for the rod and the outside diameter was just right to go in the tube (but not bind).
If you are not comfortable in "re-manufacturing" something then dont try this. If the rod doesnt go all the way down you cant shift and if it doesnt pop back up you will not be able to take your key out...trust me thats why I used the rubber piece LOL. It was not working with the rod of to one side because the piece that goes into the tube would not contact it correctly. Its probably different on the Levoc since its a whole lot nicer **** than my cheap 10 dollar autozone **** (I just wanted a **** I could paint to match).
Pic of my shifter handle:
yes its an auto with a 5 speed surround and boot.
I could have cut mine lower but that was the most comfortable height for me.
Old Mar 9, 2004 | 03:27 PM
Gjohnson's Avatar
yeah, I though you had a an auto, but it threw me off when I saw the 5 speed surrounding on your home page.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
