Fuel Pump/Gas Tank... Gasket?
Old Mar 15, 2004 | 09:09 PM
MrGone's Avatar
I would assume there is supposed to be a gasket between the top cover plate where the fuel lines/pump and electical connections connect to and the gas tank itself???
Do you guys think this would be a dealer only part? Could I just use some Black RTV? lol (the oil resistant kind, ie. what you would use for the oil pan and such).
This car is just ****ing me off.
Old Mar 15, 2004 | 09:30 PM
DanNY's Avatar
Ad·min·is·tra·tor
it's a rubber o-ring...a BIG one.
bite the bullet and get it from the dealer. gas fumes in the car while driving can't be fun.
Old Mar 15, 2004 | 09:39 PM
MrGone's Avatar
Maybe Brian sells it, or Courtesy. I dont even know where the closest dealer is.
Old Mar 16, 2004 | 09:14 AM
Matt93SE's Avatar
STFU n00b!
Any dealer will have it (or can order it), but you gotta have one...
Old Mar 16, 2004 | 09:43 AM
Jeff92se's Avatar
I'm needing a caw
Probably Kirkland Nissan is closest.
Old Mar 16, 2004 | 09:52 AM
92 Max's Avatar
Closest Dealer to Issaquah
Yes Both Kirkland and Melody Nissan (Bellevue) closed. The only left closeby are Cambell-Nelson in Lynnwood, Yonker in South Renton and the one in Seattle (can't remember name).
One's on the drawing boards for Bellvue east of downtown, but won't open until perhaps the end of the year.
Old Mar 16, 2004 | 09:59 AM
Jeff92se's Avatar
I'm needing a caw
Are you sure it's leaking from there? If you don't a gasket, you need one but if the car is sitting there, it won't leak from there.
Old Mar 16, 2004 | 10:06 AM
MrGone's Avatar
I drove about a block from filling the tank, so I have a feeling the gas from the filler tube pushed it out of that area. After that I have no idea, time to look for a new gas tank? lol
Old Mar 16, 2004 | 10:33 AM
92 Max's Avatar
Leaking Filler Tube
Are you having a problem with gas leakage and fumes? I recall there was a recall on these cars for rusted out filler tubes. Perhaps this is the problem? I pulled the rear drivers side wheel last year and pulled the plastic cover off of the filler tube. It was encrusted with packed mud. I cleaned it, inspected it for rust and sprayed some undercoating on it to protect it.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
knight_yyz
Nov 1, 2015 01:34 PM
