Is it knocking or something else?
Old Mar 16, 2004 | 06:16 AM
m_maxxy's Avatar
It happens mostly when my car is cold yet. When I idle in "drive" sometimes I feel something like stroke which shakes the whole car. It's not very audible but it feels very well through the body. In these moment rpm drops about 2-3 points and then comes back.
What can it be?
Old Mar 16, 2004 | 11:41 AM
m_maxxy's Avatar
Bump...
Anybody???
Old Mar 16, 2004 | 01:22 PM
chrgdRapa's Avatar
i got the same problem. i dont know what it is though, ive been told to replace fuel injectors and pistons cause my car runs on 4 cyl as of now.
Old Mar 16, 2004 | 03:57 PM
m_maxxy's Avatar
All my injectors have about 11 ohms resistanse which is good but still doesn't guarantee that they are ok. And I didn't notice any power loss recently so I can presume that my pistons are working more or less fine.
The bottom line is that it is a weird behaviour and so far it looks like only two of us have this problem...
Old Mar 16, 2004 | 06:14 PM
Bill Brasky's Avatar
Seperated at Birth?
Try tightening the loose nut behind the wheel. I hear that solves most problems...
I take you you guys are autos? I've never heard of this situation with them... make sure your fluid is up and bright red!
Old Mar 17, 2004 | 06:02 AM
m_maxxy's Avatar
I even replaced that nut - no help
Yes it is auto. It's really time to change my tranny fluid but I have a doubt that it causes car to shake so badly (almost jump). Anyway thanks for the advice. I'll change the fluid soon.
Old Mar 17, 2004 | 06:57 AM
internetautomar's Avatar
mod or sell?
Run some PRESSURIZED FI cleaner through the system and see if it helps.
Old Mar 17, 2004 | 08:48 AM
m_maxxy's Avatar
What is "PRESSURIZED FI" ? Is it some kind of fuel/injection system cleaner? Where can I get it?
Old Mar 17, 2004 | 09:06 AM
mod or sell?
it's the type of cleaner that is actually hooked up to the fuel rail and the car runs off of it for like 5-10 minutes. It's done by repair shops, not some thing that you'd do yourself.
Old Mar 17, 2004 | 09:36 AM
m_maxxy's Avatar
Thanks dude. I'll talk to my mechanic about it.
Old Mar 17, 2004 | 11:16 AM
ChrisCheezer's Avatar
-how about trying the EZ stuff first.
-check all your... spark plugs,wires, rotor, cap.
-start the car and let it warm then open the hood and see if it has a knock! u will see the engine shake every few sec. (when a chamber is not fully combusting)
-whats the cars idel speed?,
-does it have a hesitation?
-what does the exhaust look like? is it very black? does it smell like fuel?
Old Mar 18, 2004 | 09:18 AM
m_maxxy's Avatar
Ok, one by one.
1) Spark plugs just replaced recently. Wires, rotor, cap - to be replaced. Not sure if it can be the cause.
2) No, car doesn't have a knock according to your description.
3) Yes I have a problem with idle speed - it's about 800-850 in neutral but as low as 650 in drive. I'm trying to find a vacuum leak with no success as of yet.
4) Yes, it does have very slight hesitation. I presume it because of a vacuum leak as well.
5) Exhaust look normal. Not black.
Plus I have at least 2 broken exhaust studs.
Idle speed problem and hesitation appeared after my accident two month ago (I rolled over). But this "shake" thing happened before the accident.
I definitely know that I need two fix my idle problem and replace wires/rotor/cap before trying to fix this shake thing. I just wanted to know if somebody else in the forum had these symptoms with their car.
DC_Juggernaut
Sep 28, 2015 04:07 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
