Question about stock bose
Old Mar 20, 2001 | 07:16 AM
RitalinBoy's Avatar
How much power do the stock amps put on in the front? What is the largest size speaker you can fit in the doors with out too much hassel? And links to someone with instructions? Im looking at getting a component system and putting either 5 1/4 or 6.5 inch subs in the door and the tweeters up where the mirror is.
RB
Old Mar 20, 2001 | 09:04 AM
Czar's Avatar
Do a search on this forum for BOSE. Aftermarket speakers will not work with the stock BOSE amps.... most aftermarket speakers are 4 ohm, while BOSE amps are designed for 1 ohm speakers. I believe each amp puts out 50 watts peak. The ussually 5 1/4 work best with stock front enclosures....
Old Mar 20, 2001 | 09:41 AM
RitalinBoy's Avatar
So I gotta buy a new 4 channel amp (might as well because I will be replacing the rear speakrs as well). Hell, I think Ill just take my car into the local stero shop and have them put the stuff in then and run new wire. This is some poop. Maybe I will try myself. I don't know. I did search btw, but I got so much crap that wasn't related to my search I decied to post. If I did get new speakers, what would I need to replace? Would I need to run any new wires? Or mess with my head unit? Currently it has a wiring harness from crutchfield to allow me to use the stock amps. Would this have to go as well?
RB
Old Mar 20, 2001 | 02:01 PM
MaX93's Avatar
This is what I did:I wanted to be able to have my subs wired into my system, but i found out that the bose system was 1 ohm. I decided that i would just replace the bose system because i already had a cd deck laying around....an Aiawa 40x4 deck. Replaced the speakers with pioneers and 2 pioneer 400w 12" subs. I had a shop do all of the wiring because at the time i did not know too much about wiring aftermarket equipment. So anyway, if you want to replace speakers or the head unit, you will HAVE to replace everything to accomodate a 4 ohm system.
Old Mar 20, 2001 | 04:36 PM
190hpKiLLA's Avatar
Granny Driven
Here is some info that maybe could help u!
89 to 94 max....Reciever max depht is 7 inch, front doors 4x6 depht 2 1/2, rear deck 6 3/4
Also call crutchfeld they will help u pick out the right stuff.
###800-955-3000 or crutchfield.com
The Frye
Sep 2, 2021 11:03 AM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
