transmission filter
Old Apr 11, 2004 | 11:58 AM
dromance1's Avatar
transmission filter
[SIZE=3][COLOR=Indigo][FONT=Palatino Linotype]
Greetings Max lovers, Does the 1992 maxima GXE have a Tranmission Filter?
If transmission is slipping will it help to change the filter?
Old Apr 11, 2004 | 06:20 PM
eric93SE's Avatar
The filter is not accessible. If the filter is the same as the SE then you probably dont have to change it anyway, since its a strainer and not a cotton filter.
So what you need to do is change the fluid, use dex/Merc III. Change the fluid a few times, since you only get out about half each time you drain it out. Drive the car for a while (or even a week) between changes to let the new stuff fully circulate and eat at some of the varnish deposits.
If you tranny doesnt smooth out, then you may need a new throttle positioning sensor. Another problem might be broken nylon bushings that are located at both ends of the shift cable.
I think I'm going to copy this response so that I dont have to type it each time.
Old Apr 12, 2004 | 03:32 AM
lubricity's Avatar
Well that is a new one. Nylon shift cable bushing making the trans slip.
Do change the fluid, but it might require a band tightening. or a rebuild.
Justin Kroll
Oct 1, 2015 07:03 PM
Pied
Sep 26, 2015 03:29 PM
