AutoZone Vs Dealership
Old Apr 29, 2004 | 05:51 AM
Mike92GXE's Avatar
I know that we've discussed this before but without the search we'll talk about it again. I need to do a major tune-up and I want to know what parts would be better from Autozone or the net vs. the dealership. Money is not the issue since I will do most of the work myself. I want the most bang for the buck. If NGK sparkplug wires will give me better performance than stock ones then I would like to get those, if a bosch 02 sensor is just as good as a factory one, just $30 less then I will go with that, etc. I want to get the best value since I have the funds to do this the right way. Here are a few things that I'm looking at;
02 Sensor
Spark plugs/wires
cap
rotor
fuel filter
Gaskets = dealership
Brake cylinder gasket (is leaking fluid in drum brake)
SS or regular brakelines?
If you can think of any other preventive maintenence (sp?) parts that I should replace at the same time, feel free to add to the list. I have a WSP exhaust set up and a cone filter and the rest of the mods I have are cosmetic. I've been putting this off for a minute until I had the funds to do it all and do it right so your help would be appreciated.
Old Apr 29, 2004 | 08:18 AM
Jeff92se's Avatar
I'm needing a caw
02 Sensor - Dealer or a NTK unit
Spark plugs/wires aftermarket is okay if it's ngk/magnecore/msd etc
cap dealer
rotor dealer
fuel filter dealer
Brake cylinder gasket (is leaking fluid in drum brake) dealer because they are probably pretty cheap
SS or regular brakelines? definately ss lines if you can get them. of course it will be a non-dealer item
Old Apr 29, 2004 | 01:42 PM
MrGone's Avatar
Autozone = only good for light bulbs and a good laugh.
I would buy half that stuff at Napa because 1. they are alot closer to me than a dealer and 2. for me its cheaper than buying at a dealer.
Old Apr 29, 2004 | 02:18 PM
internetautomar's Avatar
mod or sell?
Jeff- y the gaskets dealer? you just can't buy them in Fel-Pro for a VE but he has VG.
shawn is right AZ is a major joke
The o2 will always be NTK if you buy one for our maxs don't matter where you get it.
Old Apr 29, 2004 | 02:32 PM
Jeff92se's Avatar
I'm needing a caw
Depends on where the gasket is. If it's deep in the engine, I only trust Nissan parts.
BTW. Y o-ring gaskets are actually more expensive at Napa vs Nissan discount dealers.
But Napa is a decent aftermarket parts place. They seem to hold their parts quality higher than Smucks/AutoBlown etc...
Old Apr 29, 2004 | 03:05 PM
shavedmax's Avatar
my car was tuned up with autozone crap and its running just fine, but what do i know. just buy everything from intermetautomart
Old Apr 30, 2004 | 06:06 AM
mod or sell?
Old Apr 30, 2004 | 06:19 AM
Mike92GXE's Avatar
I appreciate the help guys, automar I have a 92 GXE and my only discount is 25% through HNE at Tom Peacock Nissan down here but I will have to pay tax. If your prices are lower on these items I'll get them from you. Are your parts aftermarket or dealership. I'm going to be going with the dealership parts. I want to get the 4 wheel disc brakes with the SS brake lines but the set up to do the conversion just isn't cost effective considering the minimal difference in braking that one would see. I might need to start a new thread to discuss that one....
Old Apr 30, 2004 | 06:59 AM
mod or sell?
All of my stuff is "aftermarket" but a lot of the time the "aftermarket" stuff is reboxed O.E.
most parts are on my website.
Old Apr 30, 2004 | 08:19 AM
90SEBlack's Avatar
Dont all the parts from places like AutoZone,Napa,Advance Auto, dont they all get made bye the same company Moog,Dana,Albany,Fel-Pro,Beck Anerly dont the just box them up diff. to get the true O.E parts the dealer and New old stock is the only way to go right? and Internetautomar of course!!
Old Apr 30, 2004 | 08:33 AM
Jeff92se's Avatar
I'm needing a caw
Many companies make parts for maximas. Problem is not all companies make GOOD parts for maximas. Some are oem makers, some are aftermarket quality parts. Some are just plain crap.
Napa tends to use good aftermarket and oem makers for parts
Autozone/Schucks etc.. tend to use the crappy aftermarket makers
BTW. You manage to get those bbk brackets done?
Old Apr 30, 2004 | 08:43 AM
90SEBlack's Avatar
Ya i did umm out of Aluminum made 2 sets had a guy that was gunna buy a pair then dissapeared, So i have 2 sets in the shop one pair is mine when i find some calipers for a decent price the other is my best guess gunna sit there untill some one posts that they need a pair, And i dont dare try to sell them on here as u may ban me for life this time and not just a week lol , How much of a braking diff. did they make on your ride or are they mainly for looks and braggin rights, did u have any problems with your master cylinder displacing enough fluid to move the bigger calipers.
Old Apr 30, 2004 | 08:51 AM
Jeff92se's Avatar
I'm needing a caw
How did you make the brackets w/o any calipers?
I don't do mods for looks.
Old Apr 30, 2004 | 08:57 AM
90SEBlack's Avatar
Ur so bad *** Jeff. I went to AutoZone home of the junk and had them pull me a set of calipers mic'd them out mad a small pattern and went fromt there. Using ur pics and a scale i found the length they had to be away from the stock mounts i believe it was 3/4" between centers, havnt actually mounted them with the calipers under the wheels but they should work.
Old Apr 30, 2004 | 09:00 AM
Jeff92se's Avatar
I'm needing a caw
Bad xxxx?
Well I measured the brackets to about 1-1.5mm clearance. I hope yours turn out as good.
Old Apr 30, 2004 | 09:04 AM
90SEBlack's Avatar
Bad AZZ , I hope they work too Jeff, Would u like to see pics of them as im sure that u believe that im BS'ing Im also sure that u could care less so i prolly wont post or talk about this subject untill its on my car and i have it working.
Old Apr 30, 2004 | 09:12 AM
Jeff92se's Avatar
I'm needing a caw
No I don't think you are BSing. I saw your turbo pics. Nice.
I just didn't like someone copying my work so blatently. I don't make squat on them anyway but at least have the courtesy to explain your situation and WHY you are asking for someone else's dimensions.
Pics would be cool. But what they hell, they are just little brackets.
Post progess pics for the turbo, it's coming along good.
Old Apr 30, 2004 | 01:14 PM
MrGone's Avatar
hahahahahahahahaha. You forgot balkamp. Sooo eh, Moog is crap? Fel-Pro is crap? Beck Arnley (not Anerly) is crap? I think the progress you've made on the turbo is awesome, but then comments like that really make me wonder
Please be sure to let everyone know who is going to buy your brackets.... as they probably value their life (ie. so we can avoid riding in their car). Your looking for deminsions from Jeffy, yet your not using the same material. There is just a small itty bitty reason why him and the other BBK makers are not using Aluminum for their brackets, and cost and weight is not the reason.
Old Apr 30, 2004 | 05:31 PM
Engloid's Avatar
I like AutoZone for stuff like alternators, starters, and things with that lifetime warranty...which you never get from nissan.
For gaskets, go to ebay. I have bought full engine gasket sets OEM for $55 on there before. I have yet to see a cheaply made gasket for these engines. To my knowledge, the crappy companies must not make gaskets for them.
Another neat thing I learned recently... I just bought an old 85 Ford Ranger (beater work truck) and went to AutoZone for tuneup parts. The dist cap and rotor were actually the original ones on the engine with 142k (or 242k, I dunno) on them. They were so bad that the truck died in the parking lot, and wouldn't start. I replaced cap and wires in the lot and it fired up like new.
Anyway, while inside getting parts I commented to the guy.. "They should start making them with contacts of brass or copper." turns out they had one with Brass, and it was only $3 more.
I kinda doubt you can get the brass ones from the dealers, and I don't know if you can get them for the Maximas, but it's worth looking into if you need a cap.
Also keep in mind that parts stores are like generic food...some parts are as good as the name brand and some isn't. But remember that Kroger doesn't make any food, even if it has their name on it. They buy it already packaged their way....from a large maker of name brand food.
Same is true with a lot of your OEM stuff...Nissan doesn't make alternators, they buy them.
Old May 1, 2004 | 03:30 PM
stephenlc's Avatar
Stuff that breaks or wears away after time I get from autozone. Break it and get a new one. Especially axles. Electronics I would get from Nissan.
Old May 1, 2004 | 04:54 PM
shavedmax's Avatar
i have never heard of kroger in my life, but ill assume it's a big suprmarket chaim like walbaums, pathmark, shop rite, king kullen, or stop and shop.
Old May 1, 2004 | 05:11 PM
90SEBlack's Avatar
Well I wasnt praising Autozone or anything i was just saying that all the retail auto stores like that all carry the same crap, untill Jeff informed me that Napa has higher standards thanks for the props on the Turbo, There some new pics of my new jap motor thati got on the bottom of my site check them out ill upload more later 2night as i am late for a movie. ~ Jon
Old May 2, 2004 | 07:49 AM
90SEBlack's Avatar
Combustions chambers on the heads were polished,and surfaces were redecked, along with the intake ports getting ported to match upperintake ports and polished. Block shot peened hot tanked fluxed and then was bored .10 with new moly rings and pistons.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
