How do I PROPERLY take care of my tranny??
Old May 3, 2004 | 07:06 PM
midnight's Avatar
So I just replaced my junk tranny with one from the salvage yard. It has "over 100,000 miles" according to the guy and that's all I know. It works great now, but I'm wondering how to take care of it to make it last. I wrecked the last one by flushing it thinking that would make it last. So are we not supposed to flush these and just drain and refill them. I haven't done anything to this one yet. Can someone please give me some advice on this. Thanks.
Old May 3, 2004 | 07:46 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
get a transmission fluid cooler..cheap and easy prevention right there
don't drive like a maniac
and I guess keeping a watch of the fluid and maybe changing it every 20k miles or so(thats what I used to do after my second rebuild)...nit sure if it helped, but thats what I was told
Old May 3, 2004 | 08:11 PM
usmanasif's Avatar
Yes...do NOT flush it! That just stirs all the gunk up and the seals begin to leak.
Old May 3, 2004 | 08:55 PM
Tom's Avatar
Tom
I flush mine every 15K (163k now), but I've been doing this from the very beginning. But if you have a transmission that hasn't been flushed frequently, it's probably a better idea to drain and refill.
Cliff Clavin's Avatar
Way out West
umm, the best way to fix those crappy ATs is to do a 5-speed swap
Old May 3, 2004 | 09:25 PM
MrGone's Avatar
While you might be able to get away with that on Dodge trucks, you absolutely CANNOT get away with that on Nissans.
You scare me.
Old May 3, 2004 | 09:53 PM
bonzelite's Avatar
someone descend from the flaming heavens on this, but this is about the AT, right? manuals you can flush and flush and just flush.
or is the whole thing a myth? i flush my 5spd from time to time. and it is fine.
Old May 3, 2004 | 09:56 PM
MrGone's Avatar
no, your right Chad, just keep on your current maintence scheudle
Old May 3, 2004 | 10:10 PM
bonzelite's Avatar
much obliged, shawn. do you ever talk with sarin? he's in your neck of the woods, i'm assuming.
back O.T. - i'll continue as i am with the tranny. also, can you recommend a tranny cooler? i keep meaning to do this. but of course, you know how that goes...
Old May 3, 2004 | 10:52 PM
MrGone's Avatar
yeah, I just caravaned up with him from Woodburn Oregon to Exit 148A (IIRC) on saturday evening
I'll send you a link to some vid's we took on the way back
Tranny cooler + 5spd will require some type of pump.
Old May 3, 2004 | 11:39 PM
bonzelite's Avatar
can't wait for the link to vids.
how would you patch the cooler/pump in? would you run it off the battery like you would an amplifier? i'm a dumb-a$$ with electrical ideas. i am assuming that the cooler's plumbing is sealed or self-contained and must be pumped around itself, ie, it ain't running coolant through the engine block or tranny itself. is this correctly vague?
Old May 4, 2004 | 08:46 AM
midnight's Avatar
Can someone with a FSM add a post? Just to say what it says about how often to drain and refill. Thanks.
Old May 4, 2004 | 10:00 AM
internetautomar's Avatar
mod or sell?
probably every 25k , don't have FSM here.
Also add a bottle of Lubegard Red to the tranny when you drain and fill.
Old May 4, 2004 | 10:02 AM
MrGone's Avatar
Old May 4, 2004 | 10:18 AM
mod or sell?
www.lubegard.com
Old May 4, 2004 | 12:00 PM
usmanasif's Avatar
You scare me.
Eh...? What the heck? I was talking about NOT flushing it so as to prevent leaks. BTW, I am used to scaring people....I am 6' 3" 260lbs!
Brian, thanks for the Lubegard idea. I am going on a long road trip. Will be sure to add it prior to leaving.
Old May 4, 2004 | 12:23 PM
MrGone's Avatar
If you have a leak, fix it. A leak is alot cheaper to fix than a busted tranny from running on burn't tranny fluid.
I bet my dad can beat up your dad.
Brian, I'm still skeptical...
Old May 4, 2004 | 12:38 PM
KLoWnPR109's Avatar
I'm two inches taller than you. I win
Old May 5, 2004 | 04:05 AM
midnight's Avatar
So do you think I should drain and refill the fluid now since I bought this tranny from a junkyard and it could have sat there for the last five years for all I know?
Old May 5, 2004 | 06:02 AM
subs1000w's Avatar
it was proboly drained when they pulled it out of the car so it proboly has new fluid in it
Old May 5, 2004 | 06:39 AM
eric93SE's Avatar
There's no F-ing way they put new fluid in it.
You should definitly do a drain/fill. Hopefully their is no tranny fix crap in their.
Old May 5, 2004 | 06:49 AM
mod or sell?
Stop by your local trans rebuilder and chances are you'll see bottles of a red trans additive on their shelf.
Sometimes it's Lubegard sometime's it's a "Generic" branded version of it.
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
Noela
Sep 26, 2015 08:22 AM
