Quick q about auto tranny drain plug removing
Old May 4, 2004 | 06:58 AM
m_maxxy's Avatar
I'm gonna change ATF in my car and tranny drain plug just stuck (no surprise!)
I just want to make sure that it has a "normal" "right" thread on it, i.e. I should unscrew it counter-clockwise.
One more thing. 1/2 inch square socket to be used there, right? I tried the one that I have but eventually it just slides out of the slot every time.
Old May 4, 2004 | 07:27 AM
fugi43's Avatar
I don't remember the exact size of the drain bolt but I know its metric. That's why the socket is slippin' off. I know the bolt is a standard counter-clockwise turn to loosen. Try a light duty breaker bar if you can't get leverage to break it.
lata
Old May 4, 2004 | 07:43 AM
wawa92gxe's Avatar
You got it wright.
To loose, counter-clock-wise, 1/2 inch wrench head.
But you have to use one hand to hold /push the socket head in there and
use a metal tube or hammer to bang on the handle until loose.
it is pretty tight.
good luck.
Old May 4, 2004 | 12:47 PM
Matt93SE's Avatar
STFU n00b!
It SHOULDN'T be that tight.. too many stupid mechanics crank that thing down when they're putting it in though..
as has been said, use a 1/2" breaker bar and hold it in there while you're turning it.
when you put it back in, you only have to tighten it to like 15-20 ft.lb.. put a dab of RTV sealant on the threads before you put it in to keep it from dripping.
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
maximusrising
Sep 2, 2015 09:55 AM
Lowered_a33
Sep 1, 2015 07:49 PM
