Car shakes when breaks are applied ... ?
Old May 7, 2004 | 08:56 PM
rrrfoma's Avatar
If anybody knows what might cause it.
When breaks are applied steering wheel start shaking (higher speed - more noticeable). Seems that it is coming from the front right side.
I have checked breaks and nothing seems to be wrong.
The only thing ... I measured rotors and they appear to be a little thicker in comparison with OEM recommended.
Any ideas?
Old May 7, 2004 | 09:05 PM
MrGone's Avatar
get the rotors turned
Old May 7, 2004 | 10:22 PM
Bill Brasky's Avatar
Seperated at Birth?
uhh... did you measure them with a school ruler?
Discard spec is .787 in. (nominal is .9xx IIRC from my Bendix book.)
get them turned. check for pad wear, maybe install pads.
Old May 8, 2004 | 12:20 AM
rrrfoma's Avatar
ha-ha!!! school ruler
pads are new and rotors (bendex) are 1y old and still look perfect ... the whole year long they were just fine - I have no idea what happened, one day car just started to shake with no reason at all
Old May 8, 2004 | 12:55 AM
Seperated at Birth?
did you ride the brakes for some time? that does it. did you stop from a fast speed quickly? that'll do it. rotors aren't exactly all the awesome when it comes to staying true....
Old May 8, 2004 | 01:00 AM
rrrfoma's Avatar
yeap - for 1 year ... when it started to shake, I replaced pads - but it didn't help (but rotors look like new)
so you suggest to replace rotors?
Old May 8, 2004 | 02:19 AM
Seperated at Birth?
no... get them turned. ie: put on a brake lathe
Old May 8, 2004 | 09:27 AM
Jay93SE's Avatar
Are the caliper pins seized?
Old May 8, 2004 | 11:09 AM
Seperated at Birth?
note the "high speeds = more noticeable"....
this indicates 9 times out of 10 that the rotors are warped. i've been doing brakes for about a year and i've never replaced a caliper... pretty robust little buggers.
Old May 8, 2004 | 01:02 PM
Jay93SE's Avatar
I had the same problem on my mom's '96, turnred out that the rotors were warped 'cause the pins were seized. I figured it's worth checking befor he replaces or turns the rotors and the same thing happens! I really felt like an a**.
Old May 8, 2004 | 05:19 PM
MaximamixaM's Avatar
How is the rest of the suspension? any worn bushings, etc?
Old May 8, 2004 | 05:47 PM
rrrfoma's Avatar
no, everything esle is in good condition (I replaced struts last September - so had a chance to check everything).
I think, I'll simply replace both rotors ...
BTW, thanks for help, guys!
Old May 8, 2004 | 06:30 PM
internetautomar's Avatar
mod or sell?
Quality brembo blanks available
Lakersallday24
Jun 16, 2019 01:35 AM
Ray229Harris
Sep 16, 2015 08:16 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Balkins
Aug 12, 2015 06:39 AM
