rear factory speaker hole size
Old May 9, 2004 | 09:01 AM
swowlinc's Avatar
1993 SE
I would like to know if you take out the rear Bose speaker assembly, then what size speaker will directly fit in the opening? If you dont have the Bose in your car then what do you have back there?
Old May 9, 2004 | 09:48 AM
Cliff Clavin's Avatar
Way out West
The exact replacement for Bose is 6x9. They bottom mount, so you don't have to do anything from inside the cabin, just get in the trunk. You can use the brackets that are already there, so all you have to do is remove the four nuts per speaker and swap in a 6x9. I have Infinity Reference 6x9s in mine right now.
I think if you take out all of the bose brackets, the hole is smaller than 6x9 (possibly 6.5?) but you would have to take apart the parcel shelf and top mount them.
Old May 9, 2004 | 12:23 PM
AscendantMax's Avatar
without bose = 6.75" (most 6.5"s will work as well)
with bose = 6x9
Like Red92MaxSE said, the 6x9 just remove the 4 bolts holding the speaker up in the trunk. If you don't have bose, the rear seat and deck will need to be taken off before you can get to your speakers.
Old May 9, 2004 | 02:53 PM
swowlinc's Avatar
1993 SE
[QUOTE=Fosgate Fan]without bose = 6.75" (most 6.5"s will work as well)
with bose = 6x9
thanks
Matt93SE
May 24, 2019 02:58 PM
jskirwin
Jun 8, 2016 08:49 AM
Huttig2009
Sep 25, 2015 03:31 PM
maximaham
Aug 20, 2015 10:23 AM
Mcnabb34
Aug 11, 2015 08:45 PM
