Alarm going off for no reason, HELP!!!
Old May 11, 2004 | 10:29 AM
xilef's Avatar
The factory alarm on my '92 Maxima SE started going off for no reason. The neighbors called the cops twice allready while I was at work. It usually starts going off after standing for a couple of hours. Can someone describe a process of disconnecting the alarm on this model? I was told that there is a sensor under the steering wheel shaft that I can adjust but after checking it out, I couldn't find anything besides tons of wires. Please help!!!
Old May 11, 2004 | 10:31 AM
Jeff92se's Avatar
I'm needing a caw
It's probably one of the pin switches/ground switches on the doors/hood/trunk.
Old May 11, 2004 | 10:38 AM
ChrisCheezer's Avatar
is ur trunk closed all the way?
Old May 11, 2004 | 10:41 AM
xilef's Avatar
The trunk is closed all the way. How do I check these pin/ground switches. Is there a way to completely disconnect the alarm or atleast the siren? Thanx
Old May 11, 2004 | 11:26 AM
jwmaxse's Avatar
Is there a fuse for just the alarm? If so, then just pull the fuse and be on your merry way, unless that disables the ignition too. It's worth a try
Old May 11, 2004 | 12:05 PM
xilef's Avatar
I actually took out the fuse and the alarm was still active, I kind of assumed it would because in case someone does break into my car, taking out the fuse would be too easy of a way of getting the alarm to shut off.
AboveDaCloudz
Oct 8, 2015 11:25 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
homewrecker
Sep 24, 2015 07:01 PM
homewrecker
Sep 23, 2015 03:41 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
