replace brake lines
Old May 18, 2004 | 11:56 AM
medic's Avatar
replace brake lines
I noticed my brake fluid level is going low again. Last year when it did this was becasue my calipers were leaking so I changed them, but now I'm starting to think it may be the lines or the resivour. Any other place that's common for a slow leak to spring up. The car has 120K miles.
How tough is it to change the brake lines or fluid resivour on our cars? I'm a basic mechanic - change oil, change spark plugs, change rotors, calipers, and pads, etc.
Is this something I could do in a few hours in my garage or should this be left to someone with more experience? Anything I need to watch out for or special tools?
Thanks. Mmmm...forbiden steal braided brake lines...<drool>
Old May 18, 2004 | 12:08 PM
Jeff92se's Avatar
I'm needing a caw
Master cylinder could be leaking. Not from the outside but from the inside. Crawl under the dash and look directly under where the rod comes though the firewall. You might have to pull back the carpet/sound material to check. If it's wet, it's bad and needs to be replaced. Dry then you are okay.
Old May 18, 2004 | 03:57 PM
internetautomar's Avatar
mod or sell?
Jeff, if the master cylinder has leaked so much that he can feel it inside the car, then he'll probably need a booster too.
Old May 18, 2004 | 06:19 PM
XmaximaX's Avatar
I was working on a Max at work today, he came in with his brake light on, and his ABS control module was leaking, so check that, it's on the pass. side of the engine, near the front.
Old May 19, 2004 | 07:25 AM
medic's Avatar
jeff - thanks, I'll check that out.
xmaximax - no abs in my car, sorry, I should have mentioned that.
internetautomar - if my booster was bad, wouldn't I have to work a lot harder to stop the car...the pedal feel is fine. I thought the booster was an all or nothing device, I didn't think it went out gradually. Pardon my ignorance if I'm being dumb.
Old May 19, 2004 | 07:48 AM
mod or sell?
booster may not be bad and if the pedal feels fine it's probably not the master cylinder.
Does the pedal "sink" when you hold it down?
Old May 19, 2004 | 07:53 AM
Matt93SE's Avatar
STFU n00b!
the problem won't be the booster itself.. what happens is the master cylinder leaks inside the booster and ruins it from the brake fluid. not sure exaclty how, but that's usually what happens with it when they go bad...
Old May 19, 2004 | 08:06 AM
mod or sell?
the fluid leaks from the center bore back down the rod into the booster itself. and then eats the seal and allows the vaccum to escape.
I was just saying that IF the master went bad enough to feel it inside (liquid) the booster would have gone too.
Old May 19, 2004 | 10:40 AM
Paul89SE's Avatar
Why don't you try putting cardboard under the car in different spots? It's an easy way to tell where fluid is leaking from.
Old May 20, 2004 | 12:08 PM
Suya's Avatar
can anyone of you post a picture where exactly Master Cylinder and Booster is located and how it looks like? Past few weeks, when I apply brake, the car stops but I feel that the brake is going all the way down. I had replaced barke pads on all four wheels about 8,000 miles ago.
Old May 20, 2004 | 04:44 PM
mod or sell?
Pop your hood and look on the drivers side against the firewall. Big round thing is the booster and attached to that (infront of it) is the master cylinder.
master cylinder
Brake booster
Sopunds like your master is shot.
I sell em.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
