ut oh... metal shavings cant be good
Old Jun 2, 2004 | 01:11 PM
MrGone's Avatar
I did the ole Jeffy check (pull the oil cap and take a gander) and well....
I kind of noticed a wierd spot on the cam, so I wanted to feel if it was smooth or not, didn't really feel a difference, but I looked at my finger and there were metal shavings on it. wtf!
Round two: try again. yeap, more metal shavings on my finger. ummmmmm.....
I'll be pulling the valve cover later tonight, I'm not liking this though.
Old Jun 2, 2004 | 01:37 PM
Matt93SE's Avatar
STFU n00b!
You spent too much time with Jeff... he's rubbing off on you.
Old Jun 2, 2004 | 01:39 PM
Jeff92se's Avatar
I'm needing a caw
How does the engine run? Oil level. Don't listen to Matt. Looks like he would like to do the "rubbing" haha
Old Jun 2, 2004 | 04:03 PM
internetautomar's Avatar
mod or sell?
you need a better oil filter, and a magnetic drain plug.
Old Jun 2, 2004 | 10:49 PM
MrGone's Avatar
Jeff, Engines running good, oil level's ok. I add abit every now and then because of the front seal (waiting for UDP lol). It has never gone really low while I've owned the car because of how you say it really effects the life of the engine. I'm also careful not to overfill it though, hmmm.
Brian, meh, I'll look into the drain plug. My oil filter is a Napa Gold....
Matt, if I was local I'd be around your garage just as much
I wasn't able to pull the valve cover and check things out today, I will tommarrow. I'll see whats up
Old Jun 7, 2004 | 10:01 AM
Jeff92se's Avatar
I'm needing a caw
done yet? I can't even get to a cam lobe when removing the oil cap.
Old Jun 7, 2004 | 11:39 AM
MrGone's Avatar
yeah, not to sure what the deal was.
It wasn't on a cam lobe.
I didnt check the rear head, I'll do that some other time (ie. VTC time).
Basically I checked the oil, no metal, checked the inside of the head, no metal. It was just on the intake cam around that area where the filler cap goes. hmmm.
Really strange. Atleast I have that spare motor, just incase.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
dvcamp
Sep 18, 2015 10:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
