Bluebird AWD?
Old Jun 15, 2004 | 06:20 AM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
Bluebird AWD?
I was looking around the J-spec engine sites and one had a 1990 nissan bluebird turbo/intercooled motor with an AWD transmission. i wonder if that would bolt up to my 1990 Maxima SE ?
does this setup even exist or am i dreaming...
Old Jun 15, 2004 | 06:30 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Originally Posted by PunkFriday
or am i dreaming...
no, but you just peed the bed
Old Jun 15, 2004 | 11:56 AM
90SEBlack's Avatar
I Quit!!!!
Old Jun 15, 2004 | 12:07 PM
maximagxe90's Avatar
Hi,
that setup would not work with your fwd setup,
so don't even think about it,
Old Jun 15, 2004 | 12:56 PM
mattf16v's Avatar
I wanted to do that swap to a Stanza I had...same car so it would've worked.I doubt anyone else in the states has even bothered to do it,too.
Old Jun 15, 2004 | 12:57 PM
mattf16v's Avatar
Need to get a Sentra Se-R tranny,though,unless doing the whole AWD swap...crazy.
Old Jun 15, 2004 | 01:28 PM
nismobaron's Avatar
Car def exists - known in Japan as a Bluebird SSS ATTESSA. Have only seen it on the U12 chassis but it may exist on U11 & U13 as well.
Not sure if that car uses the SR18DET engine or CA18DET - I think it's the CA18 which means the tranny would bolt up, except the starter motor is gonna be in the wrong place. That means changing the bell housing which means pulling the trannies apart - not a good idea. Once bolted up to the engine, you'd have to see if the transfer box clears the steering rack & the front roll bar so is a major job.
Haven't looked under a 4wd bluebird so not sure how similar the rear subframe is to the max or whether it uses a similar set up to our cars. I think it uses HICAS as well.
In terms of going rwd / awd, the bluebird attessa would make a great donor car & you'd have less fabrication to do than if you tried to put a skyline rear end in. It would still require a heap of work and major fabrication, though.
Old Jun 15, 2004 | 01:32 PM
90SEBlack's Avatar
Anything can be done with a donor car ALOT of money and ALOT of time as we have seen (1990 Max with a VQ) If you really wanted to you could put a SB 350 in a max with a 9" Ford rearend but it would take alot of time and money! Is it worth it in the end? Why not just purchase the oraginal car and convert it too US specs would probably cost less and be more efficent! Just my thoughts though
Old Jun 15, 2004 | 03:16 PM
internetautomar's Avatar
mod or sell?
He|| yeah! BTW it would be easier using a 425 transaxle, screw the diff
Old Jun 15, 2004 | 03:42 PM
90SEBlack's Avatar
LOL Lets Do It, Ill be over around 9 and well get started.
Old Jun 15, 2004 | 05:04 PM
mattf16v's Avatar
The u12 "Stanza" version had the CA18DET and then the SR20DET(!!).There was a U13 "Altima" version,also,with the SR20DET.There is an Australian site that has a write-up on one....I'll try and find it to post here.
Old Jun 15, 2004 | 05:07 PM
mattf16v's Avatar
http://www.autospeed.com/cms/article.html?&A=1090
Old Jun 15, 2004 | 05:08 PM
mattf16v's Avatar
Here's the U13...jealous yet?
http://www.autospeed.com/cms/A_0140/article.html
Type97GXE
Feb 5, 2003 01:02 AM
Black VQ
Jul 26, 2002 03:53 PM
Craig Mack
Feb 20, 2002 03:33 PM
Craig Mack
Nov 11, 2001 08:59 AM
Pancor
Jan 4, 2001 09:03 PM
