question about changing gauge face...
Old Mar 29, 2001 | 06:44 PM
WhiTe93GXE
ok i have 93 gxe and i can get white gauge faces...but how hard will it be putting them in and can i do it without messing up my gauges....i think ive read in another thread somewhere that your almost certain to mess up the guages trying......i would love to change the faces but i dont want to mess anything up.....thanks guys
Old Mar 29, 2001 | 08:16 PM
ghostmax's Avatar
Where are you getting these white faces from? If they are overlays, there is a greater chance of messing up your gauges since I understand that the process is kinda complicated with the needles and stuff. On the other hand, if you're getting the whole cluster or the gauges from an SE, then the whole process is pretty straightforward. You just need a screwdriver and patience (takes around 45 minutes to an hour if you're doing this for the first time).
Old Mar 29, 2001 | 09:27 PM
WhiTe93GXE
yeah i was gonna just do the over lays, but if just getting a cluster from an SE will work then cool.......but on an SE the mph goes up to 145?..so does things match up???
Old Mar 29, 2001 | 09:34 PM
ghostmax's Avatar
Acutally, Isaacm (I think) has a GXE and replaced his cluster with one from a 92-4 SE, and he said that the numbers worked fine. So I guess it will work out. I just happened to luck out with 89 gauges which go up to 125, so I didn't have to worry about that.
Old Mar 29, 2001 | 09:43 PM
WhiTe93GXE
maybe i'll just try to look around for 89 to 91 SE cluster....they all go up to 125........well i guess its picking through the junk yards for me lol
Old Mar 31, 2001 | 10:22 AM
todamax's Avatar
Is the odometer part of the gauge cluster?
Old Mar 31, 2001 | 01:05 PM
ghostmax's Avatar
When you take apart the cluster, there are three guages: speedometer,tachometer,and the gas/temperature. The odometer is separate but is plugged into the speedometer in order to get the correct miles. It is easy to unscrew them all. Does that help?
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
cruce91
Sep 20, 2015 10:23 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
