otto 5th gen strut bar fit my GXE?
Old Jun 20, 2004 | 04:02 PM
BensMax93's Avatar
I posted about the otto bar earlier and I know a few of the guys on the .org have them. The thing is that the pic on Ebay looks like it only has 2 holes for bolts and my GXE has 3... Does the SE only have 2 bolts?? I might be missing a third hole from the angle in the pic, but it sure does look like 2...
can someone clear this up for me??
thanks
Old Jun 20, 2004 | 04:18 PM
d_warner's Avatar
Old Timer
5th gen bars will fit the 3rd gens. There are pics on my webpage of Mike92GXE's car with a 5th gen strut bar.
http://maxima.cardomain.com/id/d_warner
Can't remember which page, but theres a table of contents.
David
Old Jun 20, 2004 | 07:41 PM
Brad92SE's Avatar
The otto strut tower brace should fit without a problem, just make sure it is for a 5th gen, no maxes have only 2 strut tower bolts as far as I know.
Old Jun 20, 2004 | 08:20 PM
thumpyls's Avatar
will this also fit a 90 se..i see the white max on car domain..looks like 2 bolts http://memimage.cardomain.com/member.../232284_84.jpg
Old Jun 20, 2004 | 09:41 PM
MrGone's Avatar
It's just the pictures, the 3rd bolt is behind that bracket.
Old Jun 21, 2004 | 12:59 AM
bonzelite's Avatar
i will support the cause here. 5th gen FSTB will fit 3rd.
Old Jun 21, 2004 | 01:16 AM
MrGone's Avatar
IBtheusualsuspectsaccusemeofnotgivingmichaelcredit
Also since I know Michael will see this thread, lol. Infront of the battery, I assume yellow = headlight wiring harness, what is the red stuff?
Old Jun 21, 2004 | 05:29 AM
BensMax93's Avatar
thanks for the replies guys.. It looks like I'll be getting a 5th gen strut bar pretty soon
Old Jun 21, 2004 | 06:26 AM
Michael's Avatar
Back in a 3rd Gen.
LOL
Correct-The yellow is the headlight harness.
The red is my amp power wire. Remember I have all my wiring and such just stuck in there out of the way in that pic. I didnt put it all back after doing the painting because I had other stuff I was doing (sand blasting the battery tray and re painting it etc). Its just kinda there out of the way so I dont run over anything while driving it around the yard. The power wire isnt hooked up now anyway since I took the amp out.
back to the original question.
The 5th gen bars will fit all 3rd gens BUT on the 89-91 Max you can use the 3rd gen bar without any problems. On the 92-94 GXE and SE I like the way the OTTO 5th gen bar fits because it clears the plenum on the SE and clears the AC hose on the GXE and SE. The AC hose will have to be moved on the 92-94 Maximas (both GXE and SE) if you use the bar with the curved bracket that mounts to the strut tower and that is why I like the OTTO better because you dont have to move a thing with it.
Old Jun 21, 2004 | 06:55 AM
2k3TitaniumSe's Avatar
Let me finish it....it will fit the SE because I test fitted it on my 3rd gen before installing it on my 5th.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Stagnet04
Aug 30, 2015 07:30 AM
tgreen
Aug 27, 2015 08:34 PM
ef9
Aug 27, 2015 07:21 AM
