What to change for high performance tune-up
Old Jun 23, 2004 | 10:22 AM
swowlinc's Avatar
1993 SE
Im taking my max in for a thorough tune up so Id just like to get some info on what things I should replace and preferrably with some performance enhancing as a result. I plan on changing these things:
Plugs and wires... Help
Old Jun 23, 2004 | 10:39 AM
Jeff92se's Avatar
I'm needing a caw
Make sure to get the MSD high performance plug wires for your 1992 SE. There are turbo types that I've heard work well.
Old Jun 23, 2004 | 11:05 AM
Jay93SE's Avatar
VE= No Wires. Get NGK Coppers for plugs.
Old Jun 23, 2004 | 11:09 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
8.5MM right...
Old Jun 23, 2004 | 11:41 AM
Jay93SE's Avatar
Originally Posted by DA-MAX
8.5MM right...
Might as well add a 6AL, Blaster coil, and billet distributer too.
Old Jun 23, 2004 | 12:24 PM
thumpyls's Avatar
ngk platinum
Old Jun 23, 2004 | 12:56 PM
swowlinc's Avatar
1993 SE
ngk platinum or copper? what are these
; 6AL, Blaster coil, and billet distributer?
Old Jun 23, 2004 | 04:17 PM
Pit5Bull's Avatar
@swowlinc...
I think for the VE, platinum plugs are suggested (hopefully someone will validate that for you).
FNG is talking about an MSD Ignition system. the MSD 6AL is the ignition control device, the MSD Blaster is the ignition coil (to replace the stock one) and the billet distributor is a replacement/addtion to your distributor (if you have one...) I'm not sure about how the VE engines work, but I do know that they don't have spark plug wires, so someone with the knowledge, please spread some my brotha's way, if you don't mind...
Not pretending to be an expert, just trying to help a brotha out!
peace2u
Old Jun 23, 2004 | 05:21 PM
MrGone's Avatar
""The VE came from the factory with NGK Laser Platinum Plugs and does not have a conventional wire setup. So basically a tune up is filters and plugs. all of which I sell:" -Brian
Old Jun 23, 2004 | 05:24 PM
MrGone's Avatar
8.5MM right...
1. only get the AL if you dont have a rev limiter, or just get the 6A and never have a rev limiter and be dumb like me.
2. stop making fun of my other car
(I still need to show Jeffy the other car someday heehheehhehe)
Old Jun 23, 2004 | 06:49 PM
swowlinc's Avatar
1993 SE
Thats all?? Which filters should I change then?? Although the car runs very well, it's at 110,000 miles. Ive changed the belts and kept the oil changed and mixed with Lucas oil stabilizer. Ive also poured Seafoam in the crankcase and gas tank. What about transmission fluid and/or filter?
Old Jun 24, 2004 | 02:47 AM
Jay93SE's Avatar
I'm not making fun of your other car, I'd kill to own a '68 'Stang. I have a 6Al on my '79.
Old Jun 24, 2004 | 10:42 AM
Pit5Bull's Avatar
@swowlinc...
Do you always use the Lucas Oil Stabilizer? I heard from my oil change spot that all the commercial truck drivers use the stuff in their rigs when they get the oil changed, and it works really well. I've only used it once, and forgot to use it at my last oil change.
peace2u
Old Jun 24, 2004 | 04:10 PM
swowlinc's Avatar
1993 SE
Originally Posted by Pit5Bull
@swowlinc...
peace2u
I use it EVERY oil change with castrol gtx. And pour a little gas tank bottle in the gas tank sometimes. The stuff really clings to the gears,supposedly protecting them. Theres a demonstration machine in many advanced auto parts stores so you can see what it really does, even though they use plastic gears. Makes me feel better as I push the car quite often.
Old Jun 24, 2004 | 04:26 PM
Kyle's Avatar
Could someone please explain the no plug wires on a ve for me. Little confused on that.
Old Jun 24, 2004 | 05:32 PM
thumpyls's Avatar
its a weird set up..
Old Jun 25, 2004 | 02:24 AM
Jay93SE's Avatar
@ Kyle,
There are no plugwires, distributer etc. There is an individual coil pack on each sparkplug that fires that particular cylinder. There are also sensors on the crankshaft and camshaft that tell the ECU what positions they are in relation to each other, so it can fire the right plug at the right time. Hope that helps.
Old Jun 25, 2004 | 09:00 AM
Jeff92se's Avatar
I'm needing a caw
What sensors on the crankshaft?
@ Kyle,
Old Jun 25, 2004 | 09:33 AM
swowlinc's Avatar
1993 SE
If thats it then theres yet another reason to buy this car. Low tune up cost! I'll try BKR6E-11's this time. Thanks peeps
Old Jun 25, 2004 | 09:38 AM
MrGone's Avatar
Do you have an auto or 5spd? If auto I'd do a flush + change the filter, and add a cooler while your at it lol. If 5spd, might as well change the gear oil. I like to use Amsoil, but alot of guy's use Redline.
The only thing I would put in my engine is Marvel Mystery Oil and Seafoam.
For the filters and stuff, Fuel Filter, PCV, check the air filter, I'm sure I'm forgetting something but meh.
Old Jun 25, 2004 | 09:45 AM
MrGone's Avatar
I was just giving you guys crap, moreso Addae
Heres a pic from Jan 03:
http://digitalbeta.net/images/steering/1.JPG
Once I finish up working on Chris's car I'm heading out to the Junkyard to find a T-56 for it. Will be strange going from 3spd to 6spd . If everything goes as planned it should be a 347ci with a T-trim on it or possiable a Kennebell . I need to make a Cardomain for it with all the work I'll be doing soon lol. sry for ot.
Old Jun 25, 2004 | 02:39 PM
swowlinc's Avatar
1993 SE
5spd
Ive changed the Fuel Filter, PCV, check the air filter, but how do I change the gear oil?
Old Jun 25, 2004 | 02:45 PM
MrGone's Avatar
1. loosen fill plug
2. find drain bolt, its near the shifter linkage
3. drain it
4. put drain bolt back in
5. fill
6. put fill plug back in
Old Jun 25, 2004 | 02:57 PM
swowlinc's Avatar
1993 SE
1. loosen fill plug
3. drain it
5. fill
Where can I find the fill plug? where can I get some Amsoil?
Old Jun 25, 2004 | 03:27 PM
MrGone's Avatar
Fill plug = front right of tranny. you use a 1/2" drive rachet or breaker bar to loosen/tighten it.
Amsoil, online venders, parts stores, heck i think internetautomar even sells it. I bought mine from GiJoes.
Old Jun 26, 2004 | 08:58 AM
swowlinc's Avatar
1993 SE
Thanks man!
Old Jun 26, 2004 | 02:00 PM
Bill Brasky's Avatar
Seperated at Birth?
it must be nice to not have to change plug wires...
$72 bucks for my NGK silicone wires plus side is that they are RICER BLUE!!! w00 w00!
make sure you get a can a vaccum and hook it up to the drain plug on the tranny... makes draining a whole lot easier. check your muffler bearings and make sure that their clearances are all good (gotta use Plastigauge for that).
oh, and find some cans of compression... i hear it *really* helps out with the glow plugs and apex seals!
Old Jun 26, 2004 | 05:52 PM
ChucKfORRESt27's Avatar
You forgot to tell him about the muffler wireing harness upgrade to go with the bearings!
Maxima.KsA
May 15, 2020 04:14 PM
97_GXE
20
Sep 17, 2015 08:12 PM
carid
Sep 9, 2015 05:06 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
