VG 5-Speed Swap - Worth It?
Old Jun 10, 2004 | 09:51 AM
Nycmax92's Avatar
Automatic to Manual Conversion
I have a 1992 Nissan Maxima GXE with 103,000 miles. Approximately how much will it cost to have a auto to manual tranny swap. Labor? Parts? Total? Is it worth it.
Old Jun 10, 2004 | 09:59 AM
cneary812's Avatar
I am looking into it myself. It should be considerably less than getting a new automatic transmission put in. I saw a quote somewhere (cant remember where off hand) for about 900 installed but I am not sure if that includes the transmission or not.
it was at maximumtuning.net but that is for 4th gens you would have to call them to find out.
Old Jun 10, 2004 | 10:50 AM
dkris42's Avatar
Have not seen this post in a while.
Old Jun 10, 2004 | 10:57 AM
maximase86's Avatar
I love lamp.
For all the parts, etc, if you do it yourself, budget at least 900-1200 bucks. If you have a shop do it for you, tack on at least another 500-1000 bucks. I've done the swap before on a 4th gen, as well support a couple other local guys that did the swap on thier 4th gens. If you do it, you'll definately would need at least 1 or 2 extra pair of hands to help you. Also be prepared to have your car down for some time. On average, Joeblow should be able to do this with about a good 3-5 days worth of work...with a little knowledge of what he's doing. When we did iansw car, it took 3 weeks (actually it was 3 days of work, but because of parts issues, the car sat for 3 weeks).
S
Old Jun 10, 2004 | 06:38 PM
subs1000w's Avatar
yes the labor would be 500 to 1000
parts depend alot on where your get them but if you pull them yourself from a junkyard you could get eveything you need for under 500 easy
Old Jun 10, 2004 | 07:27 PM
todamax's Avatar
I converted my 92SE Auto to a 5-speed in April. I had a parts car that I had gotten for $800. I put in an ACT clutch and a fidanza flywheel. I also ordered new boots, master and slave cylinders, lines, mount inserts, etc. I think I spend about $1600 by the time it was all said and done. I did all the work myself, with the exception of bleeding the clutch. It took me about 40 hours of work. The cars were side by side in the driveway, so I was able to take off of one and install on the other. I also installed a CAI at the same time, as I had the whole drivers side apart.
It was actually pretty easy. I'd never done a tranny job before. In fact, my experience mainly consists of doing a topend rebild of a VG... Sooo it was a little scary. I could do the job in waayyyy less time now.
That being said, I've got an VE auto tranny for sale with 67K on it.
Old Jun 11, 2004 | 05:52 AM
GRNMAXDMON's Avatar
im still workin' on this auto to manual swap and i know i read this in here before but still tryin' to figure out what exactly do i have to do to a VE 5-speed to work right with my VG. i know someone on here did it and it worked just fine. the reason being because isn't the VE 5-speed tranny better or stronger than the VG 5-speed tranny???
todamax: BTW is that VE tranny a 5-speed???
Old Jun 11, 2004 | 12:32 PM
subs1000w's Avatar
im pretty sure thonly thing different about the ve and vg trannys is the ve one has the lsd but i dont think the VE one is any stronger although i will know for sure in the comming weeks
tom use a VE tranny in a vg you need
ve lsd tranny
ve axles
ve hubs
thats the only difference from the vg to ve
yes the VE manual transmission is 5spd
the ve auto is 4spd
Old Jun 21, 2004 | 04:15 PM
Laly's Avatar
so a can buy a wrecked VE and swap the tranny, axles, and hubs and ill have lsd? im looking to do the swap in my vg. i wasnt sure if i was limited to only using a vg tranny. thanks
joshua
Old Jun 22, 2004 | 10:13 PM
GRNMAXDMON's Avatar
ok now that being said about VE and VG 5-speed trannies... do any of u guys know who exactly made the VE 5-speed work with a VG motor???
Old Jun 24, 2004 | 08:16 AM
-shock211-'s Avatar
Hey people,
Haven't posted in quite some time. Did some lurking though..
Anyways,
This question is for those of you who have done a manual to 5-speed swap.
Was it worth the work?
Have you had any problems since the swap?
I'd really like to do the swap but I'm trying to decide if it will really be worth the effort involved in such a project.
I'd obviously do the swap myself to keep labour costs out of the equation.
Did you guys buy used manual trannies from the wreckers or japanese import shops?
I'm not interested in finding a VE 5-speed, it's VG 5-speed or bust for me. It seems that VG 5-speeds are terribly hard to find though.
Another question,
Did those of you who did the swap use the VE LSD tranny or the VG tranny?
I'd rather pick up an LSD tranny if I can but I guess we'll see what happens.
I have the write up printed out somewhere for a 4th gen tranny swap. I know there was a write up on a 3rd gen tranny swap though, so where could I find that?
Thanx,
Ryan
-shock211-
Old Jun 24, 2004 | 08:20 AM
KLoWnPR109's Avatar
Only problem I had was the tranny blowing up on me and having to get it rebuilt
Old Jun 24, 2004 | 10:18 AM
-shock211-'s Avatar
so you got a used tranny that wasn't in great shape?
let me guess....the bearings wear worn?
Old Jun 24, 2004 | 02:43 PM
2k3TitaniumSe's Avatar
Just find a used 5 speed VE. Nothing's better than the power by the VE30de.
Old Jun 24, 2004 | 03:00 PM
ChrisCheezer's Avatar
im doing a 5 speed swap now, still looking for parts money isnt the problem, everything is pretty cheap.
from what i herd the only hard part is mounting the new clutch and brake pedal, i have done that and it wasnt to hard... u hafta make a custom spacers for the clutch. (no biggie) still trying to find parts and tranny... vg lsd!
if u can get all your parts for cheap, the swap is worth it.
good luck
Old Jun 24, 2004 | 04:10 PM
KLoWnPR109's Avatar
You've been looking for parts for like the past 2 years. Have you even actually gotten anything?
Old Jun 24, 2004 | 06:01 PM
thumpyls's Avatar
yes its worth it
Old Jun 25, 2004 | 05:57 AM
-shock211-'s Avatar
where's jon91se?
i think i remember reading he did the swap...
Old Jun 25, 2004 | 07:51 AM
WWWHHHHAAAATTT yyeeaahhh
2 years? more like 2 months.
im working fulltime now, landscaping, so this project is going to take longer then i thought...
Old Jun 25, 2004 | 08:09 AM
-shock211-'s Avatar
bump!
i wanna know the answer to this as well.
Old Jun 25, 2004 | 08:20 AM
Jeff92se's Avatar
I'm needing a caw
How's the TT project going?
Old Jun 25, 2004 | 08:37 AM
KLoWnPR109's Avatar
That's probably how he managed to run a 16.9@89 at the track, or at least he did according to the cardomain page.
Old Jun 25, 2004 | 08:38 AM
-shock211-'s Avatar
huh....
jeff,
did you just copy and paste my thread to this???
Old Jun 25, 2004 | 08:40 AM
Jeff92se's Avatar
I'm needing a caw
It's called "merging" threads. Too many similar questions and too little researching by the noobie members
Originally Posted by -shock211-
huh....
jeff,
Old Jun 25, 2004 | 08:43 AM
-shock211-'s Avatar
oh i see... Good Job
Old Jun 26, 2004 | 01:03 PM
16.9... try 14.9! w/NNAAAAZZZZZ yo!
lol.. ef that crap!, im stupid
if u really wana do a conversion on our 3rd gen's GO FOR IT! parts arent that expencive.... as cheep as or cheeper then getting a rebuilt auto, that will fail again.
Old Jun 27, 2004 | 12:06 AM
GRNMAXDMON's Avatar
thats true cuz im really getting sick of my auto tranny not workin' properly. i've done tranny fluid changes every month because my damn tranny keeps going straight to second gear and third gear but not 1st or overdrive at all. i have to step on the gas a little and then it engages to 1st, 2nd, and 3rd but not overdrive. im tired of this crap with these damn trannies on our 3rd gens so basically i still want to know if the VE 5-speed tranny is any good to work with my VG motor or should i just get a VG 5-speed???
Old Jun 27, 2004 | 04:18 PM
Golden Ice's Avatar
...i used to think I wanted to do a 5 spd swap..and I would if I could find a nice cheap 70s or earlier caddy in good running condition, but I want an auto so I'm not always driving a manual..I get kinda tired of driving my 4 spd truck somtimes..
I imagine its worth doing if you have somthing else to drive and a good garage to work in...if I get another auto, I'll prolly garage the max and start the show car transformation, starting with some way overdue maintenance..i cant AFFORD to drive my truck everywhere, so I've been babying the max with an old timing belt...25-35 mpg is worth the risk..my truck gets 3-5 on a good day off a cliff with a tail wind..
Old Jun 27, 2004 | 04:24 PM
internetautomar's Avatar
mod or sell?
Gimme a 75 eldo with a 500!! slam an intake and you gain like 100hp (seriously)
Old Jun 27, 2004 | 06:04 PM
Evil_Twin's Avatar
I am looking into that soon, but more of switch the tranny and to a VE.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
