pcv valve question?
Old Aug 24, 2004 | 09:32 AM
Maroon'dMaxSE's Avatar
pcv valve question?
is it true that you need to buy another part to replace/install a new pcv valve? like an extension hose or sumthing? what is it exactly? thanx
Old Aug 24, 2004 | 09:36 AM
-shock211-'s Avatar
i didn't...i just replaced the pcv valve a couple months ago and everything went smooth. my mileage got a hair better too
Old Aug 24, 2004 | 09:53 AM
smokyman13
nope...just carefully take of the hose on the new one.....unscrew the old valve, screw the new one in....carefully put hose back on new one.....should only take 5 minutes or so
Old Aug 24, 2004 | 09:55 AM
thumpyls's Avatar
no other parts needed..follow smoky's plan and ur set..be sure not to tighten the valve 2 much
Old Aug 24, 2004 | 09:59 AM
smokyman13
ya hehe...never tighten anything too much to the engine....torque it to specification if you have a torque wrench...I've already ****ed up and tightened a bolt too tight on my oil pan and *snap* I got half a bolt in my engine!! pcv valve would be alot harder to snap tho because its pretty thick......all in all, easy installation....and if its a bad valve your replacing, you'll be glad you replaced it, new valve is $6
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
