changing ATF fluid
Old Aug 25, 2004 | 12:42 PM
aminus21's Avatar
changing ATF fluid
Any tips for changing ATF fluid. CAr has 100k miles (90 GXE), should I change the filter too and gasket?????
Any type of ATF like Chevron???
Just drain and refill???
should I get something like this: http://www.expressautoparts.com/Part...20Filter%20Kit
does the tranny need to be removed to change filter??????
Thanks EVERYONE in advance...
Old Aug 25, 2004 | 02:52 PM
jaguax's Avatar
Just drain it and refill it with the same amount that drained out.
Except by doing this you are not getting all the old fluid out. There will still be a lot of old fluid throughout the tranny. The only way to get all the old fluid out is to do a tranny flush like they do at Jiffy Lube. Of course you could drain and refill a couple of times, say like once per week. That way you are more likely to get a lot of the old fluid out.
I've read that the flush could be dangerous if you have high miles though because it will loosen up dirt and stuff and cause leaks and ultimately a broken tranny. Don't ask me how true that statement is know, but it was said on this website by many different people.
Old Aug 25, 2004 | 05:02 PM
bhunter's Avatar
Be careful. If the transmission was serviced regularly you probably are alright. If it never has or has been a real long time it could kill it. Have someone who knows what they are doing look at your fluid.
Old Aug 29, 2004 | 04:17 PM
aminus21's Avatar
Thanks for all the advice everyone. I just changed the fluid today. Simple drain and refill. I'll probably do it again in a few weeks.. just a note: the haynes manual says the bolt to drain the fluid can be opened with a 3/8 ratchet, but it actually needed a 1/2 ratchet (atleast on my car)
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
iamute
Sep 20, 2015 05:22 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
