Fog lights
Old Sep 13, 2004 | 03:59 PM
Harvs94max's Avatar
Fog lights
I just picked up some oem foglights off a 94 se and i tried to put them in my gxe but one problem there is no place to mount them i thought they would just bolt right up. Is there another bracket that attachs to the frame that i have to get or do i have to wam bam up a bracket to make them fit. does the fog light bracket attach to the frame or to another bracket that attaches to the frame.
Old Sep 13, 2004 | 04:03 PM
Knight4's Avatar
There is a bracket. I got it when I bought some OEM foglights from another org member. Haven't had the time to look, yet, to see how they actually bolt up.
Old Sep 13, 2004 | 06:26 PM
DaWifey's90's Avatar
what can my max do for me
oh oh oh...i know this one....
the fog lamp has a pivot point on the top of which is the mounting point with 2 holes at the rear most end and an upward hook at the front most end (some may call this a bracket). this mounting point then mounts to a metal plate more appropriately termed a bracket. it has four holes in it. the rear most two have nuts welded to the topside (this is what the bolts which go throught the fog lamp mounting grab on to) the other two line up with holes at the bottom of the bumper which also have nuts welded to the topside.
Old Sep 13, 2004 | 07:01 PM
Geerhed's Avatar
Moved on to BMW's :(
t the other two line up with holes at the bottom of the bumper which also have nuts welded to the topside.
What size are the nuts? 10mm?
Old Sep 13, 2004 | 07:43 PM
thumpyls's Avatar
nice max..i used the aftermarket piaa's bracket that came with them..i also have the oem bracket..if u need them..email me
Old Sep 13, 2004 | 08:17 PM
GRNMAXDMON's Avatar
did u just get the fogs with the wires or with brackets as well. the holes should already be there. also r u usin' an aftermarket fog switch or stock switch. if u have the stock switch and ur car already has the fog harness and relay then the holes have to be there. i used my stock brackets to mount my aftermarket fogs and it holds up just fine.
Old Sep 14, 2004 | 08:20 AM
Harvs94max's Avatar
everything is there i used to have foglights that came with the car but they were alot smaller but the had nissan stamped on them i could tell a dealer had put them in but i hit a racoon and then i bought some cheapes from autozone but they were to small so i bought the oems thanks alot everyone for the replys ill take a trip down to the bone yard today oh i cant wait to update my pictures my car looks totally different
Old Sep 15, 2004 | 03:28 AM
the nuts are square and welded
the bolts used are m1.6-10 i believe....they're 10mm
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
