cooling system problem
Old Sep 18, 2004 | 11:22 PM
dragon_m's Avatar
I have no idea what is going on with my car. My radiator blow couple week a go. I went to the junk yard got a use radiator. Chang the thermostar also. Now my car still get overheat after run it about 5 min. all the hose are full of cooland(upper and lower hose i know this because i try to squeez the hose. I did not change the water pump because i don't know how to take off the timming belt cover. My a/c and heat is out, When o turn the fan from the a/c it doesn't do anything. Please help me guy
thank
Old Sep 19, 2004 | 06:54 AM
internetautomar's Avatar
mod or sell?
Problem 1: Junkyard radiator
Problem 2: you didn't diagnose the cause, just the effect.
did you change your radiator cap?
Did you check to see if there was any flow through the radiator?
Did you bleed the system?
Does your Radiator fan motor turn on?
Who says your car is overheating?
Just some basic questions to get you started on your journey to enlightenment :P
Old Sep 19, 2004 | 09:42 AM
dragon_m's Avatar
So you think i should go get new radiator and new cap. Yesterday the temperter meter was at top not in the middle. My radiator, the upper hose and lower hose are extremly hot. I don't want to blow another radiator. The radiator fan motor is on. I already flush the radiator 2 time with water before put cooland in it, there wasn't anything flow through the radiator. Cooland just sit in one place the car still running but the radiator, upper and lower hose got extremly hot after 5 min
Old Sep 19, 2004 | 12:09 PM
mod or sell?
by that description, I'd replace the water pump or at the very least inspect it.
Old Sep 19, 2004 | 01:14 PM
dragon_m's Avatar
Dear internetautomar
I have try to remove the tamming belt cover out but what should i do with the bottom timming belt cover. It seem like it stuck with the crankshaft pulley. I saw in this book it talk about the punchmark but when i open the timing belt upper cover out i couldn't find the puchmark. I also see they are talking about " confirm that NO.1 Cylinder is at TDC on its compression stroke". what does it mean and what do i do when i change the timing belt so it will line up right. How do i know the thickness gauge is right
My car is nissan maxima GXE single cam
thank
Old Sep 19, 2004 | 05:48 PM
mod or sell?
in short, you need to take your car into someone who can handle it. It appears to be more than you can handle
9aj9
Apr 5, 2020 12:11 AM
Smackasmith
Feb 1, 2016 12:40 AM
220k+ A32
Sep 11, 2015 02:18 AM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
